Originally Posted by LarisJaris
I have a 2003 Everest. We are on a 50A-30A reducer. We left for the day yesterday and while we were gone the park shut off the power. When we came home we only have power tp 1/2 the trailer. Tried resetting the breaker checking the GFI, checked fuses. Nothing
Any suggestions?
When you say 50A-30A reducer, can you explain exactly how the adapter (proper term for what you are calling a reducer) is?
Are you plugged into a 30 amp shore power receptacle with an adapter and then have your 50 amp shore power cord plugged into it?
The reason I need to be exact is that a 50 amp RV has two incoming hot legs to the electric panel inside the RV. Half of your RV is on one hot leg and half is on the other hot leg.
If only half is working, then it is likely one leg is not getting powered in the electric panel.
If you are connected to a 30 amp receptacle, which only has ONE hot leg, then the adapter shares/jumps this one leg across both legs in the RV. You could be having an adapter problem.
Can you please explain in exact detail to what you are connected to and how your adapter is adapting.
Pics of the adapter setup and your electric panel inside your RV would help more than you know. I am actually writing a tutorial for our forums on adapters as we speak.
