Old 08-01-2013, 12:26 AM   #1
no power except microwave and plug ins
my fifth wheel has no power except when plugged in and then only the microwave & plug ins, inverter shows the battery is charged, everything was working fine coming back from holidays until I was almost home, pulled over and went into trailer and nothing would work! any suggestions?
Pfunk7775 is offline   Reply With Quote
Old 08-01-2013, 01:30 AM   #2
Rebel702's Avatar
Do you have a battery disconnect? Or resettable circuit breaker on near battery cables.
List your model info so we can help.
Rebel702 is offline   Reply With Quote
Old 08-01-2013, 02:11 AM   #3
bikendan's Avatar
first, it always helps to post year, make and model of RV that you have.
second, was the battery recently removed or have you had it checked? do you have a battery disconnect switch installed?
third, you have a CONVERTER, not an inverter, that charges the battery when you're plugged into shore power. an inverter converts 12v DC battery power to 110v AC power, to run things like tv's and dvd players.
Old 08-01-2013, 05:52 AM   #4
caper's Avatar
Check fuse for converter, (auto style fuse) if fuse is OK then check converter for power. Check your 7 way plug. we had a person at the CG last year that had his 7 way short out and it caused the fuse in the converter to fail.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 08-01-2013, 06:36 AM   #5
TURBS's Avatar
If you don't have a multimeter now is the time to buy one and leave it in the camper.
As suggested above you need to start checking for voltage at various points to find the issue/issues.
Converter may have failed.
Converter breaker may have tripped.
Fuses may have blown.
Resetable circuit breakers may have tripped.
Need make and model of converter to get you a troubleshooting guide.
Turbs
Old 08-01-2013, 09:57 AM   #6
trailer is an 08 flagstaff fifth wheel, I reset the circuit breaker by the battery
but now this red thing (circuit breaker?) inside the fifth wheel neck ( hook up to truck) is clicking and sparks once in awhile
Old 08-01-2013, 10:11 AM   #7
update: turned all the circuit breakers back on ( I had turned them off when I was trouble shooting because converter was super hot when trailer was plugged in to house) nothing came on right away but tried the slide out and it worked, looked at everything else and its all working now that thing in the tongue has quit making noise ( what is it?) and also what would cause the circuit breaker to need to be reset? thanks for your help its been greatly appreciated!
Old 08-01-2013, 10:14 AM   #8
also it was the inverter I was looking at,its right beside the battery and shows how much dc power there is when it's on
Old 08-01-2013, 10:26 AM   #9
TURBS's Avatar
That red thing is another circuit breaker.
Get a new one of the same amp.
Turbs
Old 08-01-2013, 10:57 AM   #10
okay I will, thanks a lot
Old 08-01-2013, 11:44 AM   #11
rotorhead1250's Avatar
Sounds to me like the converter failed.
Matt & Kathie
2022 Cedar Creek
rotorhead1250 is offline   Reply With Quote
