Old 06-16-2024, 11:04 AM   #1
No power on battery
Hi, I have a 2011 forestriver freedom 1640ltd and know nothing about wiring, so please forgive any errors in terminology. Box is a wf-8712-p. I've just replaced the CO/LP detector. Everything works on shore power, but nothing works on the battery. All the grounds were jumbled together in a large blue wirenut, including a thick white wire that has a warning label about reverse polarity will damage a diode in the battery charger. All fuses are good, including the one outside by the tongue. We're getting proper voltage at the box on battery, but nothing works (water pump, lights, alarm). Also, the large white wire with all the other grounds will be negative when on shore power, but when we switch to battery is suddenly shows the same voltage as the battery. It comes out of the box with all the other hot wires.
So, my questions:
1. Why isn't anything working on battery?
2. What is that large white wire and why is it hot on battery power? And why is it jumbled up with the grounds?
Thanks everyone!
Amy
ID:	301028   Click image for larger version
ID:	301029   Click image for larger version
AmyC is offline   Reply With Quote
Old 06-16-2024, 11:16 AM   #2
NEAR the battery .....
many setups have a battery disconnect switch ... it turns OFF the battery power to all the trailer.
well mostly all.... some items such as aftermarket may still work. but it is safe to say anything fused on the fuse panel will be isolated
There is also some small 12v breakers between/near the battery and the isolation switch.. they have little tiny buttons you have to push to reset.
https://www.google.com/search?q=12v+...iverforums.com
your converter (battery charger) is a 12v power supply that will power all of your 12v items ... even if the battery is disconnected
so on shorepower 120v... you have infinite 12v power no matter what the battery is doing.
Tarpon Springs FL
2022 Salem 24RLXL
Aussieguy is offline   Reply With Quote
Old 06-16-2024, 11:47 AM   #3
If 12V stuff is working on shore power but not on battery power, I suspect a bad connection to the frame.
On shore power your converter provides 12V positive and negative to the fuse panel and everything works. On battery the +12V is getting to the panel but the negative (from the frame is missing). I think that messing with the mess of wires in the blue wire nut or other wires in general broke the connection to the frame.
On mine, the battery connects to the frame at the front and my fuse panel connects to the frame just below the panel. There is also a ground wire for the 120VAC side of the power panel connected to the frame at the same spot.
2019 Palomino Solaire 147X
2013 Ford F150
TacomaJoe is online now   Reply With Quote
Old 06-16-2024, 12:56 PM   #4
bikendan's Avatar
Just so members know, the OP has a popup, so no factory battery disconnect switch.
Old 06-17-2024, 09:45 AM   #5
That jumble of wires in the wire nut needs to connect to the battery negative terminal. You are reading voltage on it because everything is connected to the battery positive post and voltage is present through all of the loads.
The path on mine is from the battery negative post to the frame, along the frame, then from the frame to the wire nut and panel. You are hunting for a missing connection in the negative path.
2013 Ford F150
Old 06-17-2024, 11:13 AM   #6
Chuck_S's Avatar
Sure you didn't blow the battery protection fuses or the circuit breaker under the frame? White is ground on DC house wiring. Check for voltage out of the frame circuit breaker -- shore power needs to be disconnected to check this.
-- Chuck
Chuck_S is offline   Reply With Quote
Old 07-05-2024, 06:42 PM   #7
I appreciate all your help! I finally found some time to tinker with the trailer today. We replaced the corroded fuse by the battery and cleaned some rust off the ground connection to the frame and now everything works!
Old 07-05-2024, 10:05 PM   #8
Glad the issue is resolved.
The ground connection or battery negative connection to the frame should be an annual maintenance item. We clean battery connections but what about the other end of the cables? Make sure the connection is clean and tight. I also added some conductive electrical paste to the point where the negative cable is bolted to the frame. These areas are typically exposed to the environment and its effects.
Bob
Bob K4TAX is offline   Reply With Quote
battery, no power, power
