Old 05-18-2022, 07:11 PM   #1
No power to outlets
I have a Clipper 17bhs. Everything works fine, but my outlets. Inside and out. All fuses seem to be good and no breakers tripped. Any ideas?
BayouMetoNate is offline   Reply With Quote
Old 05-18-2022, 07:15 PM   #2
Check your GFCI in your bathroom or kitchen
MR.M is offline   Reply With Quote
Old 05-18-2022, 07:24 PM   #3
It’s the same deal. Took the cover/faceplate off and didn’t see anything odd. Its reset and all. Makes me think it’s something simple I’m overlooking
Old 05-18-2022, 07:26 PM   #4
Retired Army MSG!
lazyjj's Avatar
Is your AC running? Other 120V appliances going?
lazyjj is offline   Reply With Quote
Old 05-18-2022, 07:34 PM   #5
A/c is not running either.
Old 05-18-2022, 07:35 PM   #6
Retired Army MSG!
lazyjj's Avatar
If at a campground, check your power pedestal where your shore power cord is plugged in. The breaker may be off at the pedestal. If plugged in at home, check breaker on the circuit that your unit is plugged into.
Old 05-18-2022, 08:25 PM   #7
What do you mean by pedestal?
Old 05-18-2022, 08:28 PM   #8
Retired Army MSG!
lazyjj's Avatar
Is your trailer plugged into a power outlet? Campgrounds have a power pedestal that you plug your electrical shore cord from your trailer into.
Old 05-18-2022, 08:33 PM   #9
bikendan's Avatar
First question: is the trailer plugged into shore power? If not, the outlets nor the a/c won't work.
Sent from my SM-G781U using Forest River Forums mobile app
Old 05-18-2022, 09:29 PM   #10
Plugged into the house.
Old 05-18-2022, 09:46 PM   #11
bikendan's Avatar
What kind of outlet is it plugged into? If a 120v outlet, are you using a dogbone adapter or a puck adapter?
Old 05-18-2022, 10:58 PM   #12
Please tell us you haven't plugged into a regular 30 amp household outlet. If so, disconnect immediately and come back for advice.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 05-19-2022, 01:25 AM   #13
Check that the outlet that you are plugged into actually has power. If you are plugged into a GFCI circuit, the GFCI for the circuit the trailer is plugged into may have tripped.
NavyLCDR is offline   Reply With Quote
Old 05-19-2022, 06:58 AM   #14
Georgia Rally Coordinator
aceinspp's Avatar
If your plugged in check your panel in the camper and press the battery level button. It should show all red indicating fully charged if not then you may have a converter that went belly up. Later RJD
2020 Shasta Phoenix SPF 27RKSS
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
Days camped 2020 49 days camped 2021-74 2022-18 days
Old 05-19-2022, 12:18 PM   #15
If you have good shore power (my microwave display lets me know I have power), then I would lean to GFCI issue. Will the TEST and RESET buttons work on the outlet. If the buttons don't work, its probably missing AC and will be a break between the outlet and circuit breaker panel (assuming the breaker is not tripped. I'm thinking that all of the outlets are controlled by the GFCI.
2019 Palomino Solaire 147X
2013 Ford F150
TacomaJoe is offline   Reply With Quote
Old 05-19-2022, 12:45 PM   #16
Mr. Dan's Avatar
So you think the OP’s air conditioner is on a GFCI circuit and all outlets are on a GCFI circuit. I doubt it. I hope not. We don’t know if the microwave works. We were told everything works except the outlets but, oh yeah, the air conditioner also doesn’t work. Microwave? No definitive word yet.
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 =108/'21 = 115/'22 = 68; Booked for 2022 = 41
Old 05-19-2022, 02:09 PM   #17
I don't think the air conditioner is on a GFCI circuit. My AC comment, referred to 120VAC no the air conditioner. I use "AC" for power, and "A/C" for air conditioner. In OP's case, I think everything is good except for the outlet circuit.
2013 Ford F150
Old 05-19-2022, 02:17 PM   #18
aceinspp's Avatar
Need an up date from OP. Later RJD
Days camped 2019 62
Old 05-19-2022, 02:34 PM   #19
Mr. Dan's Avatar
So when the OP says in post #5 "A/c is not running either", do you think the OP means his air conditioner is not running (all is not good except for the outlet circuit) or his entire 120vAC system is not running (all is not good except for the outlet circuit)?
Old 05-19-2022, 02:51 PM   #20
Kanadian Kamper
kenandterry's Avatar
What type of outlet from the house are you using?
Is it brand new?
Does anything work in that outlet before you connect your Clipper?
Do you have a digital meter to confirm the power reading?
Agreed. We need an update from the original poster (OP).
Ken and Terry
2018 Sunseeker 2430S-CD carried by a 2017 Ford E450
Former Georgetown 330TS owner for 10 years with more mods than I can count.
kenandterry is offline   Reply With Quote
no power, power
