No power to trailer from battery
We have a Rockwood Roo that we picked up from the dealer yesterday after getting the Moryde steps replaced with Torklift steps. While on the dealer's lot, I extended and retracted both slides to check some other work they had done so the electric on battery was working at that time. When attaching the trailer plug, my husband accidently tried to insert the plug upside down. He corrected that but when we got home, we had no power in the trailer - lights, pump and slides won't work. Our battery monitor says 100% at 13.0v. The lights and slides work fine when we plug into shore power. The front tongue lift is working off the battery. All the circuit breakers are on, there are no burned out fuses inside by the circuit breaker and the battery disconnect is showing connected. Any ideas of what we can try before we take the rig to a shop; waiting weeks to get an appt and more weeks to get it back?
2021 Rockwood Roo 23IKSS "The Roadrunner"
2019 Ford F150 4X4 Ecco Boost with Max Tow Pkg
Two retirees & Tigger the lover cat
Boondockers since 1982
