Originally Posted by Bob414
A fully charged battery is approx 13.2 v. Unless your battery is bad, very low or has a high drain, 12.65 v reading does not mean your battery is charging. Just my 2C worth.
Bob
Incorrect. Voltage readings area as follows:
14.4V converter charging battery in bulk mode
13.7V converter charging battery in normal mode
13.2V converter charging battery in trickle mode
12.7V camper not plugged in, battery fully charged
12.4V camper not plugged in, battery at about 70% charge
12.1V camper not plugged in, battery at about 50% charge
Note the above will vary slightly with temperature, voltmeter, and load on batteries when voltage is measured. Also assumes a working converter. A non-working converter will be the same as the "camper not plugged in".
Fred W
2019 Flagstaff T21TBHW A-frame
