Nobo 10.5 / 6 Solar
I'm relatively new to my 10.5 Nobo and looking to add solar. I plan to mount my solar panels on the roof and connect the wires to the outlet on the side of the trailer when parked. I've been scouring the forums and haven't found any posts that explain how to connect up the charge controller using the existing port / wiring.
Does the port on the side have pig tails somewhere near the battery that I can connect up to my charge controller? I took the cover off the wiring near the solar port and see the wires go down under the trailer, just not sure where they go. I haven't taken off the bottom plating on the underside of the trailer yet to see where they go, and was hoping someone here had experience adding solar to their 10.5 or 10.6 using the solar prep from the factory.
