Old 06-23-2024, 04:55 PM   #21
Originally Posted by Lovgrel View Post
There is power going into this he gfi and out of the gfi, and all the circuit breakers have power at them.
As PopFla and others have pointed out, to have just one GFCI in a rig that large would be highly unlikely. It's either in the bathroom or the outside kitchen.
Any chance you could take a picture of the outlets in your bathroom and post it here (as an attachment)?
2015 Dynamax REV 24TB class C
Reverse_snowbird is online now   Reply With Quote
Old 06-23-2024, 04:58 PM   #22
Yes, they do
On the gfci’s the island is the only one that has a reset button, can’t imagine all the other outlets that say gfci protected go thru that one gfci?
Yes, the labelled outlets are all wired downstream of the GFCI outlet that has the buttons. It's a common practice in RVs and residential construction.
In your case, there might be TWO GFCI outlets, each with some downstream outlets.
And, a 50-amp RV like yours actually has TWO 50-amp feeds. That's why the breaker is really two 50-amp breakers coupled together. It is possible that power for one of those two has failed upstream of your pedestal. Contact the office where you are staying.
Larry
Larry-NC is offline   Reply With Quote
Old 06-23-2024, 05:38 PM   #23
Update gfi
Thanks everyone now I fee like an I Dior there was a 2nd gfi in front bathroom which I didn’t see earlier. Rest that one and everything works now.
Lovgrel is offline   Reply With Quote
Old 06-23-2024, 05:39 PM   #24
Found the other gif in the half bath which I didn’t see earlier thank you everyone
Old 06-23-2024, 05:39 PM   #25
fipntdot's Avatar
Glad you found it. Thanks for letting us know how it worked out.
22 Freedom Express 257BHS
19 F-150 3.5 Max-Tow
fipntdot is offline   Reply With Quote
Old 06-23-2024, 05:55 PM   #26
Thank you for letting us know. It's hard to see those GFCI outlets sometimes.
We have one in the kitchen that took us some time to locate and our kitchen is very tiny.
Your problems may be able to help someone else in the future. Thanks again.
Old 06-23-2024, 05:57 PM   #27
It would seem they would make these more noticeable
Old 06-23-2024, 06:32 PM   #28
deep red nail polish works for noticability
then you can tell less knowledgeable people ... press the one with the red dot
PS ... in todays world
whom you ask for nail polish is not so simple anymore!
Tarpon Springs FL
2022 Salem 24RLXL
Aussieguy is offline   Reply With Quote
Old 06-27-2024, 08:38 PM   #29
Just hooked to shore power and we have no 130 volt power, our air works and there is power at the pedestal. Any idea on why this is doing this, everything worked at our other campground this morning?
I'm a full-timer and I have been to two campgrounds where the breaker on the post was bad only half of my outlets worked luckily there was a maintenance guy that
was able to diagnosis and replace the breaker
jdkbrooks is offline   Reply With Quote
Old 06-28-2024, 07:47 AM   #30
For comparison, I had a 50 amp RV that seemed to have shore power. One a/c worked bur the other didn't. Slowly everything started failing. It turned out the shore power only had 1 phase working. I would start your gen to see if everything works to eliminated most of the issues you are having.
GEEZERS is offline   Reply With Quote
Old 06-28-2024, 07:58 AM   #31
To eliminate some possible issues, I would start your gen to see if everything works. If it does, could be the shore power has only 1 phase. Happened to me one time and one of the ac worked but the other didn't.
Old 06-28-2024, 08:05 AM   #32
The OP found their issue back in post #24.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=101
