I want to replace the Onan generator fuel filter on my 2012 toyhauler. It looks as though they installed the genny and pulled the fuel and electric lines tight at the factory. There is no play in these lines.
The genny is sandwiched between frame rails and there is no way to replace the filter without pulling the whole genny out if the trailer.
Any tips or advice from experienced rv folks would be helpful.
Other than removing the fuel and electric lines completely from under the unit, I can't seem to get it out.
You should be able to replace the filter internally. Remove the door, remove the potted circuit card, might need to remove the air filter assembly too. The pump and filter are behind the card.
