Old 06-01-2019, 04:48 PM   #21
Originally Posted by Iwannacamp View Post
Thirty would be a minimum to me.
Seafoam is the best “snake oil” ever made. There is no telling how many million$ that stuff has saved...yes I sold it for 20 years.
that's why i mention a strong mixture . Not 1 or 2 oz a gallon but 8 or more . won't hurt anything and will clean it up faster . then once clean you can mix it with other gas to dilute
MR.M is offline   Reply With Quote
Old 06-01-2019, 05:11 PM   #22
Iwannacamp's Avatar
Originally Posted by MR.M View Post
Yes and now because of ethanol it happens twice as fast
I’m don’t have experience with the alcohol and gumming, but I know it causes the aluminum to corrode.
2017 Puma 297RLSS
Old 06-02-2019, 11:37 PM   #23
nexcompac's Avatar
So I’m thinking of replacing the carb, I tried to clean it and ran fuel and sea-foam but still not running like it should.
I looked online, and found some on Amazon, but at a fraction of the cost! That is usually a red flag. Thoughts?
https://www.google.com/aclk?sa=L&ai=...7820%26psc%3D1
26' Forrest Sierra Toy Hauler
26FBSP
Pulling toys for my boys!
nexcompac is offline   Reply With Quote
Old 06-03-2019, 12:13 AM   #24
Just as confused as you
Scrapper's Avatar
All I know is when I had a 2011 Silverado FlexFuel and it started to randomly throw check engine my chevy dealer service manager told me to run a tank of E85 through it about every 6 months to keep the injectors clean. Never had another check engine afterwards.
Richard & Jill
Old 06-04-2019, 07:03 PM   #25
Daycruiser's Avatar
Nope, this is not going to cut it. You can't just run Seafoam through it and expect magic. Take off the carb and take it to a shop and ask them to clean it, they will tank the carb for a long while. Resemble and run fresh 89 oct through it, you may need to readjust the needle valves for slow and high speed. Once running correctly then add Seafoam 1 to 2oz per gallon of gas in the tank all the time. Run the engine every 30 days with load.
Retired 2020.
46 Years RVing and no end in sight.
2018 Ram 3500 SB Limited, CC, 6.7/Aisin, 4X4, SRW. Comfort Ride Energy Absorbing Hitch.
2020 Cedar Creek Hathaway 34IK, Reese 19K Sidewinder PB.
Daycruiser is offline   Reply With Quote
Old 06-04-2019, 08:01 PM   #26
Iwannacamp's Avatar
I have bought several carbs from eBay and Amazon....prolly 10 or more(I don’t take very much care of my 2cycles) and only got 1 bad one for an Echo trimmer, but I have had lots of carb trouble with that(kits cost more than a cheap carb on 2 cycle). I always look at the reviews if I doubt.
Repair or replace at your own choice. Me? New one and keep the old for a rainy day project.
2017 Puma 297RLSS
Old 06-04-2019, 08:08 PM   #27
HONDAMAN174's Avatar
So I had the same problem with a friends unit but was still under “warranty” with the dealer so I stepped away from messing with it. Dealer sold him a new carb and put a fuel cutoff switch down stream to turn off and run out of fuel.
Just glad to get away
Old 07-08-2019, 08:11 PM   #28
nexcompac's Avatar
So we replaced the carb and still had issues, we took it to a shop and they said the carb was not running correct because the throttle screw was screwed all the way out. [emoji19]
26FBSP
Old 07-08-2019, 08:11 PM   #29
nexcompac's Avatar
We added another fuel filter, and shut off valve.
26FBSP
Old 07-08-2019, 09:17 PM   #30
BobHanke's Avatar
[QUOTE=nexcompac;2135982]So we replaced the carb and still had issues, we took it to a shop and they said the carb was not running correct because the throttle screw was screwed all the way out. [emoji19][/QUOTE
A Toyota dealer pulled that on me many years ago to sell a full engine rebuild. Fortunately a local service station found his trick and bailed me out.
"Lurch" = Georgetown 2011 330TS
Toad = Jeep 2016 Cherokee
Pilot = Bob
First Mate = Xiangbing
Crew = Radar, NiuNiu & NaNa
BobHanke is offline   Reply With Quote
generator, onan
