01-21-2021, 09:16 AM
One green wire
Putting in a new Suburban Hot water heater SW6D with direct ignition.
My existing hot water heater has a 12v igniter with 2 wires coming from my circuit panel. So I will reuse the (2)wires from my existing HW to the new Suburban wall on/off switch. The 12V wires coming from my circuit panel will hook to the new wall switch then (2) new wires will hook up with the HW tank control module to the new switch as well. Don't have any questions with all of this. That's pretty clear on the wiring diagram.
However, I do have a "green" wire that is screwed to the HW tank "housing" which is a ground wire I assume. My only queston is, do I hook this ground wire to the ground wire coming from my circuit panel as well, or do I hook this green wire to a "separate" metal ground location somewhere on my camper ??
01-21-2021, 10:20 AM
to the frame.
01-21-2021, 10:30 AM
Kanadian Kamper
Yup......good and solid frame ground.
Ken and Terry
01-21-2021, 10:45 AM
run wire to frame ,round crimp on end and a self taping metal screw,socket head and a drill. scrape frame at attachment point.
01-21-2021, 10:58 AM
Unless someone knows for sure what the green wire is for it may be that the green wire is a bonding ground wire and the other end is already terminated to chassis ground. I think the OP should check with existing heater manufacturer be it Suburban or otherwise. JMO
01-21-2021, 11:26 AM
According to the wiring diagram provided by Suburban on that model, the green wire in the junction box is chassis ground.
Looks like the yellow wire from the control module also connects to it.
01-21-2021, 03:02 PM
Thanks everyone. That's kind of what I thought, but I wanted to confirm.
The diagram shows (2) wires to ground which one is to my circuit panel and the other ground would be chassis ground.
Thanks again..
01-21-2021, 03:13 PM
Thanks again..
When it comes to RVs it is always best to check and double check. The industry has no convention that is used for wiring or anything else. Ughh
Our built-in Radio/Speaker System that runs on 12 VDC was powered with 2 white 14 gauge wires. Nothing technically wrong with that. But it just proved to me they use what ever is available if they run out of whatever is specified.
01-21-2021, 03:32 PM
My camper is setup permanent in a campground and is enclosed all the way around. So I'm going to have fun trying to find a location for a chassis ground to attach my green wire too.. ugh !!!
01-21-2021, 03:39 PM
Just as confused as you
As said, that green wire may already be attached to the chassis, if you have a multimeter it can easily be verified using the ohms or continuity function.
bubbles, the OP has been given copies to his original WH manual and the service manual for Suburban water heaters in another thread about this same subject.
https://www.forestriverforums.com/fo...se-223453.html
Richard & Jill
01-21-2021, 03:42 PM
Why not just butt splice the new green wire to the old one and re-use it?
TT - 2021 Rockwood 2608BS
TV - 2020 F-250 XLT 4WD SRW 6.2L gas
