Old 05-03-2023, 08:52 AM   #1
Outlet Cover
Hi,
Looking to replace outlet cover for shore power on 2014 Solera.
A piece broke off the other day. The question is do I need to replace the entire outlet or is a cover available? Looked on Furrion site and found nothing. Thank you all
BPetz is offline   Reply With Quote
Old 05-03-2023, 09:27 AM   #2
Photo?
30a or 50a?
There are many different ones.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 05-03-2023, 09:38 AM   #3
30 amp
Old 05-04-2023, 11:00 AM   #4
You are going to have to replace the entire receptacle.
NavyLCDR is offline   Reply With Quote
Old 05-04-2023, 12:26 PM   #5
I don’t recall the exact prices but the Furrion 30amp power inlet was excessive to me in cost when mine stripped out a wire screw when adding my EMS. I replaced it with the cheapest one on Amazon, still working fine.
2019 Cherokee Wolf Pup 16BHS flipped axle, 5K springs, 400AH LiFePO4, 3K inverter, 200W CIGS solar
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package, ITBC, Tow Mirrors, 3.55, SumoSprings, 7000# GVWR, 1990#CC
Husky Centerline TS WDH 400-600# spring bars
Boomerweps is offline   Reply With Quote
Old 05-04-2023, 03:07 PM   #6
Thank you all
So the question is can a less than mechanical person like myself do it or is it a shop thing?
Thanks again
Old 05-04-2023, 03:46 PM   #7
We have no clue what your "less than mechanical" skills are so we have no way of answering that honestly.
It will take a couple GOOD screwdrivers, maybe a putty knife or utility knife and some sealant (maybe both butyl tape and real R/V sealant) You "may" need to trim the wiring and insulation if the connections are not good or possibly corroded due to the cover being missing/broken and you'll need to get the wires back in the same places on the new one. (take a photo) And by all means, unplug the cord before starting.
cover
