Old 07-06-2020, 04:42 PM   #1
Outlets not working
Hi. We are taking our first trip in our rv. I’m trying to charge my computer while driving so we can use TripWizard, but non of the outlets are working. Do they not work when you are driving?
Emily
Royandemily is offline   Reply With Quote
Old 07-06-2020, 04:55 PM   #2
Need to be plugged in for the 120v outlets to work if there is no inverter installed.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 220 AH Battery Bank (Two-GC2) - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre with Tow Package
Boon Docking 99% of the time.
boondocking is offline   Reply With Quote
Old 07-06-2020, 05:10 PM   #3
Do you have an on-board generator in your Georgetown?
You can run it going down the road to provide 120v.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 07-06-2020, 05:11 PM   #4
or get a simple $10 Power Inverter off the shelf in the tire/battery section of wmt to easily give you a working 'outlet' while traveling....easy! It works off the round 12v plug that any vehicle should have.
The Turners...
formerFR is offline   Reply With Quote
Old 07-06-2020, 05:23 PM   #5
Smile
Thank you! Yes, we have a generator, but I didn’t know we could turn it on while driving. Will definitely pick up a 12 volt plug in thing.
Emily
Old 07-06-2020, 05:39 PM   #6
if you pick up the '12v plug in thingy', you won't even NEED to run the generator while driving! Fun!
I've used this one for years, and recently picked up two for my cars, just in case - they are inexpensive and nice to have when you carry a laptop or something that requires a 120v outlet....
https://www.walmart.com/ip/EverStart...oaAh8mEALw_wcB
Old 07-08-2020, 11:49 AM   #7
Keep in mind that most cigarette lighters.. err I mean 12V power ports in vehicles can not really push more that 100-150 Watts regardless of what the plug-in-thingy is rated for. I have a 450W inverter that comes with a plug in thingy and a set of wires. The manual points out that if you need to draw more that 100W you should wire it directly to the battery.
Most personal laptops are probably under 100W. If you have a large engineering laptop like I do 150-200W is possible.
Something to think about.
Jim M.
2020 Flagstaff Super Lite 26RBWS
Former: 2017 Rockwood MiniLite 2104S
2015 Silverado 2500HD 6.0L Gas
jimmarako is offline   Reply With Quote
