Old 03-22-2024, 12:15 PM   #1
Panel on Curved Roof; Inverter
I'll be mounting a 100W panel, length 42", on the fiberglass roof of my HW277. The ends of the angle (renogy tilt mount kit) will be slightly off the roof. Does it seem reasonable to layer VGHB or eternabond tape to fill the gap? If not, then what?
Other question is a Renogy 700W inverter I want to install in the water filter compartment. Weight is about 5 lb and wall won't support. Would 1/4" plywood fastened to wall and extending down to the RV floor be sufficient to support?
William6 is offline   Reply With Quote
Old 03-22-2024, 12:29 PM   #2
Trailer Park Supervisor
NJKris's Avatar
Sounds like plywood you planned would hold it. Don't like idea of mixing electric and water. I've had leaks in wet bay before. Location should be as close to batteries as possible.
Yes, I drink the water!
NJKris is offline   Reply With Quote
Old 03-22-2024, 01:49 PM   #3
Taping my panels to my roof made me nervous so I went nuts and used aluminum track mounts. My roof is curved and that solved that problem. I just attached to tilt mount to the rail track. I started with two panels and ended up with six mounted this way. I used a stud finder to located the ceiling cross braces to attach the track. Those panels are secure.
ID:	297956   Click image for larger version
ID:	297957   Click image for larger version
2015 Chevy 2500HD 6.0 4x4 CC SB
2021 Salem Heritage Glen 290RL > GenY
1600W solar > 10,700Wh LiFePO4 > Victron MultiPlus II > Cerbo GX
corn18 is offline   Reply With Quote
Old 03-22-2024, 03:40 PM   #4
Nice looking installation.
Bob
Bob K4TAX is offline   Reply With Quote
Old 03-24-2024, 05:35 AM   #5
Thanks,
The "wet bay" is the only accessible inside space close enough to the batteries. Besides, power center/converter is below the shelf for the "wet bay".
Old 03-24-2024, 04:44 PM   #6
Did you consider the truly flexible BougeRV Yuma CIGS panels? They can be had with grommets or butyl tape. They are rather long or large.
I installed last year two 100 watt compact CIGS panels last year and have two more to install later in the spring.
2019 Cherokee Wolf Pup 16BHS flipped axle, 5K springs, 400AH LiFePO4, 3K inverter, 400 watts CIGS solar
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package, ITBC, Tow Mirrors, SumoSprings, 1990#CC
Husky Centerline TS WDH 400-600# spring bars
Boomerweps is offline   Reply With Quote
Old 03-25-2024, 01:23 AM   #7
I considered flexible panels in general and decided against flexible panels.
Old 03-25-2024, 09:30 AM   #8
CIGS panels are NOT the same as traditionally marketed “flex” panels. Flex panels still have glass in them and are as flexible as plastic cardboard, bending mildly before being significantly damaged. CIGS panels are shipped rolled up.
My initial install:
Old 03-25-2024, 09:31 AM   #9
Can anyone tell me why this picture keeps posting sideways?
It is correct in my library.
Old 03-25-2024, 09:45 AM   #10
Mine does that, too. I have to open the picture on my laptop and then just save it and then it posts correctly. No idea why it does that.
Old 03-25-2024, 10:21 AM   #11
This is what scares me with flexible panels. I would want those CIGS panels for sure.
inverter, panel, roo, roof
