Patio and aisle lights out
Hello fellow travelers. I hope everyone is well.
Earlier today, I changed out our patio light. Straight swap of the old incandescent fixture, with the new LED fixture. Two wires on and off. Nothing to it. Immediately after the installation, I tested the light via the small panel to the right of the entry stairs as you walk in. It worked perfectly. Also on this panel are the battery disconnect switch, the stair control and the patio and aisle lights. A couple hours later I went to turn the light on and it would not light. I also noticed at the blue light on the switch to turn the light on did not come on. The same can be said for the aisle lights and their switch; the lights do not come on switch does not light up blue. These two systems are pretty the only ones affected. Please help.
Thank you!
