This isn't as 100% simple as moving cords. BUT, it'll save you the hassle of having to worry about the converter and moving plugs around.
What I am planning to do is pickup a pair of the Xantrex "
Inline Transfer Relays." There's another brand of the same thing that was recommended to me here but I can't find the name/link right now.
Here's my plan:
You're specifically looking at the 1000W inverter portion on the left. Coming off of that are 2 heavy duty extension cords. These are going to be ran/fished to behind my circuit breakers.
The "AC Input 1" of the "inline transfer relay" will be plugged into the extension cord - one per cord.
The "AC Input 2" will come from the power that is currently feeding my circuit breaker that I want to power with the inverter. In my camper's case, 90% of my outlets come from 2 breakers.
The "AC Output" will go back to the circuit breaker that I removed the wire from before adding the transfer relay.
