Old 07-03-2022, 10:38 PM   #1
Plethora of Issues
Hi! So as we were packing our 2011 Shasta Revere Travel Trailer for a trip, we noticed it had a faint high pitch squealing sound coming from the fuse panel, which has since gone away. We noticed the house lights flickering and the breaker panel fan cycling on and off for just a few seconds at a time, struggling to continue running. Now we found the hot water heater will ignite right away when turned on, stay lit for 5 seconds or so, then shut itself off and ignite again, similar to the timing of the breaker fan timing. Could these all have a common problem or do we have a perfect storm of issues?
Ardententhusiast is offline   Reply With Quote
Old 07-04-2022, 04:27 AM   #2
Have you checked your battery? These all sound like electrical issues and that's where I'd start. It's possible that your converter is going bad, but start with the battery.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 07-04-2022, 06:43 AM   #3
Oaklevel's Avatar
X2
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 07-04-2022, 05:29 PM   #4
Battery is new and still good. Tested at the breaker panel, 120 all good, but the 12v fuses were reading in the 2-5 range, so guessing we're getting a whole new convertor.
Old 07-04-2022, 06:38 PM   #5
jeff64's Avatar
My guess on a 2011 unit is poor connections from battery back. Start there and renew connections to frame and terminal blocks. Use voltmeter and work your way forward
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
Old 07-04-2022, 08:34 PM   #6
Now a "Top Member"
EdJunior's Avatar
If it's the gas that is igniting, then stopping, check the burner and/or gas lines. You may have some critters (spiders, dirt daubers, etc.) that may have nested on your burner. The symptoms you describe is exactly what mine did on my old TT. The tech cleaned up the burner (dirt dauber nest), and all was well.
Ed and Sharon
2010 Wildcat 28RKBS
2019 Ford F-250 XLT - AWESOME Truck!
Retired AF MSgt
