Old 03-12-2016, 02:41 PM   #1
plugged in camper no power
2007 40ft. Cherokee Wolfpack fifthwheel toy hauler. Went to plug in camper for first time this year to clean, no power what so ever, have power going to camper & in all cords, from where you plug camper in to the breaker panel none.... please help, worked fine when we shut it down last October, is it a converter issue?
dfenendael is offline   Reply With Quote
Old 03-12-2016, 04:32 PM   #2
Do the 110 volt AC outlets work. If so look to the disconnect switch and the converter. If not look to the breaker panel.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 03-12-2016, 04:52 PM   #3
Have no power coming into the breaker panel from the main leads.
Old 03-12-2016, 05:15 PM   #4
Flybob's Avatar
Do you have a surge protector? If so it may have sensed a problem and shut down the power entering the RV.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 03-12-2016, 05:17 PM   #5
No surge protector, have power with battery. But none in the breaker panel
Old 03-12-2016, 05:18 PM   #6
Is there an inline protector some where?
Old 03-12-2016, 05:19 PM   #7
All the fuses are good also
Old 03-12-2016, 06:57 PM   #8
Do you have a generator and transfer switch? If so it could be your transfer switch. Otherwise if there is voltage at the plug and nothing at the panel...only place left to check is the plug and wire. You can take the cover off the junction box that connects the cord to the romex that goes to the panel.
2015 335DS
Old 03-12-2016, 07:16 PM   #9
caper's Avatar
Are you plugged into a GFI outlet? Is there power at the outlet (use an other electrical item to check)?
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 03-12-2016, 07:41 PM   #10
Ohmed out the wires, & there was contenuity, no generator.
Old 03-12-2016, 07:44 PM   #11
Ohmed out the wires behind panel, there was contenuity, thats why none of this makes sense.
Old 03-12-2016, 08:21 PM   #12
So you have power on the shore power cable up to where it enters the RV, but not to the distribution panel? Is that correct?
Does the cable plug into the RV? If so you may have a bad connection in the plug mounted in the RV.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 03-12-2016, 08:29 PM   #13
hammer55's Avatar
double check the neutral, there is usually a neutral problem when you have power (voltage) and still nothing works, check all connections and terminals, just a thought
Mark & Annie
2014 COACHMEN PURSUIT 27 KB
Modesto, Central California
hammer55 is offline   Reply With Quote
Old 03-12-2016, 08:32 PM   #14
Yes correct we have power on the shoreline up to where it enters the rv, but not to the distribution panel. Yes the cable plugs in to the rv. That would be great if thats the problem, that would be an easy fix.
Old 03-12-2016, 08:39 PM   #15
We were thinking about a neutral problem also, but geez where to start on that..... just don't understand how nothing wrong all last summer, we winterized it. Then today, nice day, so decide to open it up to do a little cleaning, plug it in & nothing. Just irratating.
Old 03-12-2016, 11:40 PM   #16
GLCM Warrior
Lefty59's Avatar
If you are certain you have power at the cord end where it plugs into the outside of the RV and you've ohmed out the wiring from there to the back of the distribution panel then I'd suspect a bad main breaker might be the problem. Maybe you can remove the breaker and do a continuity test on the breaker itself?
Might also suggest using an outlet checker to see if a wiring fault shows up in any of the circuitry. I'd turn all the breakers off except the main and one other and then work my way through testing each circuit separately.
Best wishes in finding the problem!
2014 Wildcat 312QBX
2014 Ford F350 SD 4X4 CC LB 6.7L PSD
Bob & Debbie, USAF Retired
Lefty59 is offline   Reply With Quote
Old 03-13-2016, 12:22 AM   #17
B and B's Avatar
Unplug the trailer, check the wiring behind the inlet. My neutral was loose from the factory. Tighten all connections.
Old 03-13-2016, 03:33 AM   #18
Thanks everyone! Will try again in the morning to solve it!
Old 03-13-2016, 06:20 AM   #19
I couldn't tell from your posts but make sure that you disconnect your battery first (if it's charged up and connected) before you start using fingers and tools on the service side of your panel. The 120V might be dead but the 12V probably isn't
2010 Wildwood XLite 26BHXL
2013 Ram Outdoorsman 5.7l
Ontherock is offline   Reply With Quote
Old 03-13-2016, 08:50 AM   #20
hammer55's Avatar
is there a disconnect, from the receptacle a junction box, open the panel check terminals, it is just slow and steady elimination,
Mark & Annie
camper, power
