Old 09-20-2021, 12:39 PM   #1
Portable solar suitcase
Hi Everyone. I have a 100 watt Renogy solar suitcase. How do I test its output? When I hook it up to my two 6 volt batteries hooked in series it will only get to a max 12.4 volts and never register higher. I have left it in full sun for hours and it never charges above 12.4 volts. My batteries will fully charge to 12.7+ when generator is used or on shore power. Is there a way to test the solar panels output? I do own a multimeter but am not very well versed in how to use it. Any detailed instructions would be greatly appreciated
Capt Dave is offline   Reply With Quote
Old 09-21-2021, 08:33 AM   #2
SeaDog's Avatar
Make sure you have the controller set to the correct type of battery I made that mistake on my Renogy 200 after putting it to the correct type it charged correctly. Just something to check.
Retired Navy
2016 Flagstaff 26 FKWS
Old 09-21-2021, 02:57 PM   #3
Hclarkx's Avatar
My thoughts ........
Your suitcase has the Voyager Charge controller, right?
Does your voltmeter agree with the LCD display in the Voyager?
Do you see a rising voltage before voltage stops rising at 12.4V?
At what time of the day are you seeing 12.4V?
Does the "System Status" icon on the Voyager make sense? Does it indicate active charging is occurring? And, of course, there is no error code showing?
2020 GMC Denali 2500HD Crew 4X4 Gas 6.6L
2015 30' 8280WS Rockwood Ultra Lite
Solar, LiFePO4, 12V fridge, mini split
100% dry camping and boondocking.
https://hclarkx.slickpic.com/gallery/?viewer
Hclarkx is offline   Reply With Quote
solar
