Originally Posted by Bbouch84
Ok so we are very new to the whole solar power stuff and would like to do tons more boondocking but my question is. Can you replace the factory 1000watt inverter in the epro and geo pro with say a 4000watt inverter so you can power your A/C. And what else would you need to do to power the A/C off the inverter?
More battery storage...
A/C will pull about 2000watts for a 13500btu unit... (15amps at 120volts)
Amps x Volts = Watts
Or
Watts / Volts = Amps
So...
A 2000watt load (microwave, toaster, hairdryer or air conditioner) will require about 170 amps of 12v power...
If you have 200 amp/hours worth of battery storage, that's only 1 hour of A/C operation before your batteries are FLAT.
Microwave ovens and the like, don't run for very long, so they won't draw down the batteries as much.
So...
In order to run your life while Boondocking you'll need enough solar and wind (don't forget wind) to generate over 170 amps of 12v power during the day, and enough to replenish the batteries when you aren't running the AC.
I'd be looking at 3000w of solar with 600w of wind. (Or more)
