Power Issue
Ok let me try to explain this the best I can. First of all I have a 2004 Sierra 30RL 5th wheel. Now here we go when I am hooked to shore power in CG my AC running after a while with say the microwave running it kicks out the AC breaker. When I reset it it will run and after an hour or so it trips again. Could it be that the power at the pedestal be lower than it should be causing it to trip? I have an Elixer-60 power supply and the AC is on a 20 amp side of a 30/20 with the 30 being the main.
Next ? is can I up the breaker to maybe a 30/25 or not? Also I have a 15amp breaker that says Gen I guess it means generator ?? not sure but I do not have a generator so could I use it for the AC if I put in a 20 or 25amp breaker??
2004 Sierra 330RL 5th Wheel
2002 Silverado 2500 Duramax 4x4
States I have camped in
