Old 04-04-2014, 08:25 PM   #1
Power issues
Replaced my 30amp breaker been doin fine now I'm camping and having a shortage of power with fridge and lights any ideas
jscarnes is offline   Reply With Quote
Old 04-04-2014, 08:43 PM   #2
rjf7g's Avatar
Have you checked the power provided by the campground? If they are giving you less than 30 Amps, you would have problems like this.
2006 Palomino Puma 27FQ Bunkhouse
2007 Gulfstream Innsbruck 36FRS Park Trailer
rjf7g is offline   Reply With Quote
Old 04-04-2014, 08:44 PM   #3
No but wouldn't the other campers be having problems too
Old 04-05-2014, 10:09 AM   #4
The frig runs on 110VAC or propane but requires 12VDC for the control circuit. The lights are 12VDC. Perhaps the 12VDC side of the electrics are the problem. Check the battery voltage - you need at least 12 volts -
The 30 amp breaker is tied to the AC - TV - and some outlets. Does the AC work:?
cadman99 is offline   Reply With Quote
Old 04-06-2014, 03:14 PM   #5
Pretty sure that my converter is bad
power
