08-02-2024, 05:43 PM
Power loss
I have lost power to my electric fireplace and the GFCI outlets only. Everything else in the camper works. They share a tandem circuit.
08-02-2024, 05:55 PM
Have you reset the GFCI
2016 Siverback 33IK, Towed 60K+ mile
08-02-2024, 05:58 PM
Yes
08-02-2024, 08:11 PM
Originally Posted by coachet7
Yes
If it reset then there is power at the GFCI. A GFCI will not reset if there is no power to it.
So, your GFCI socket has voltage at it?
08-02-2024, 09:35 PM
I had something similar happen and I had to replace the GFCI receptacle entirely. That solved my problem. It just wouldn't reset at all.
08-03-2024, 07:05 AM
I guess a more appropriate answer would have been I attempted to. There is no power to the GFCI outlets. The other outlets work.
08-03-2024, 07:06 AM
Thanks I will try that.
08-03-2024, 07:22 AM
Why don't you use a meter to see if there is power to / from the GFCT before replacing it.
I'm not a fan of wasting $ and just throwing parts at repairs.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Lillie Boxer Mix (RIP)
08-03-2024, 07:27 AM
X2 Back home we call that troubleshooting.
No idea what camper they have but my fireplace and GFI are on different circuits.
2022 Rockwood 2511S
2018 F150 3.5 Crew Cab 4x4
Max Tow Package 1855 Lbs Payload
Husky CenterLine WDH
08-03-2024, 08:03 AM
X3. It is amazing the amount of posts that describe electrical issues, and there is no mention of what the measured voltages were and where.
In ours, the fireplace and AC share a breaker. The receptacles are on another.
To the OP, maybe it's a dumb question, but what other devices are working?
08-03-2024, 08:16 AM
5 minutes with a multimeter and the guessing is over.
Quick question... since the GFCI didn't reset, (likely meaning it has on power) did you check the GFCI circuit breaker in the power distribution box? Turn it completely off and then back on.
Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=101
08-03-2024, 09:16 AM
i'm pretty sure i don't everything. but what is a tandom circuit?
do they share a common circuit breaker or are the fireplace and gfci outlets on separate circuit breakers?
have you tried to reset the actual circuit breakers?
if this is a 30 amp rv and you say other device work the issue is at least past at the circuit breakers in the panel out to the outlets. if 50 amp it may be losing power on one incoming power leg.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
08-03-2024, 11:36 AM
There are two things to understand about GFCI systems:
(a) there is usually ONE GFCI outlet.
(b) there are several GFCI Protected Outlets
If the GFIC (a) trips, all outlets described as (b) won't work.
You will need a voltmeter to determine if there is voltage from the converter panel to the source or input side of the GFCI outlet. If voltage is present, then check the voltage on the LOAD side of the GFCI outlet. No voltage here indicates a tripped GFCI outlet or a defective GFCI outlet.
Flip the breaker in the converter panel for the GFCI circuit to OFF. Then press the reset button on the GFCI outlet and then flip the circuit breaker ON.
I always analyze and diagnose the failed part before spending money at the store.
Bob
08-03-2024, 12:20 PM
They may be possibly meaning a tandem circuit "breaker" as explained in post #3 in this link.
https://www.forestriverforums.com/fo...ml#post2399055
2011 Flagstaff 831 RLBSS
What if UFO's are just billionaires from other planets?
08-03-2024, 12:49 PM
Duplicate post.
I sure wish there was a mobile app!
08-03-2024, 12:50 PM
This was supposed to say the GFCI likely has NO power.
Too much time passed for me to edit my dyslexia.
08-03-2024, 12:55 PM
A mobile app would likely cure your dyslexia!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 =108/'21 = 115/'22 = 135/'23 = 78/'24 = 83; Booked for 2024 = 42
08-03-2024, 05:33 PM
To me a tandem circuit is two circuits wire to one circuit breaker terminal.
I did that with a couple of small circuits I added that are not used together instead of buying a tandem breaker. The breaker's terminals had crimp humps for two wires. It did not pass inspection when the house went on the market.
Electrician fixed it. How? He added a short wire to the breaker and then pigtailed both circuits off of the one wire. That passes inspection. Go figure.
Now you have a potential spot for a loose connection in my opinion.
Pretty sure this might have been either just the inspectors opinion or it is a local reg.
We had a missing ground anyway on another circuit that he fixed. That on was not my doings. Was that way from way back I guess.
2022 Rockwood 2511S
08-04-2024, 06:45 AM
Originally Posted by wmtire
thank you for the explanation and picture. i understand about the slots on the breaker panel and all the different breaker types shown in the picture. i guess i never equated the word tandem to the breaker that feeds two separate circuits from a single slot. but the two circuits are independent of each other, with their own breaker, and having one of the breakers trip will not affect the other circuit. our house panel is full of these types of breakers!
08-08-2024, 07:55 PM
Longshot but we recently had an issue with the GFI outlets going out as well as the refrigerator. Took some time, but turned out. Somebody tried running too many electronics, and it actually popped the reset on the inverter. Hit the reset And everything came back on
