08-06-2021, 12:01 PM
power only works when microwave is running.
I have 120 V to the circuit breaker panel but the*power only works when the microwave is running.
I ran the microwave to see if it worked, and set it for 9 seconds. For those 9 seconds everything worked, then when the 9 seconds were up, everything shut down again.
08-06-2021, 12:23 PM
I’d start by checking all electrical connections at the panel/converter. Make sure there are no loose or disconnected wires.
I sent this to my brother who is an electrician for his thoughts.
08-06-2021, 12:39 PM
Fascinating. Absent a feat of magic, I'd say there are some really, really big problems in your service panel. If your microwave is on it's own circuit breaker the only thing common to the other circuits is Neutral and the Ground. This is not a good situation. If you are not versed in electricity I highly suggest you enlist the services of a competent electrician to sort it out.
2016 Salem 27RKSS
08-06-2021, 12:41 PM
Is your RV of the 50 amp or 30 amp type?
What are you currently using for 120 volt AC power?
2011 Flagstaff 831 RLBSS
08-06-2021, 12:43 PM
Trailer Park Supervisor
And define 'no power'. No power to AC outlets? Or no power to anything including all your DC circuits.
Yes, I drink the water!
08-06-2021, 12:50 PM
Yup, seen it before. 240 VAC service and one appliance on one side of the busbar was feeding power through it to power the other side of the busbar.
Ray
2020 Georgetown GT5 34H5
08-06-2021, 12:55 PM
50 amp
08-06-2021, 12:56 PM
50 amp. I have 50 amp shore power at my home.
08-06-2021, 01:00 PM
open neutral somewhere. could have easily damaged other items
2024 Artic Fox 3018 5th Wheel
Grand Design 2800BH TT 2021 - for sale
Prior TT 2017 Flagstaff 831CLBSS Classic Ultra lite - SOLD 5/21
TV 2024 F350 DRW - on order
Prior TV 2017 F150 6.5' bed 3.5 Eco-boost Max tow 1800lbs payload
The microwave has power. Volt meter reads 120 V from panel main breaker to ground bar, zero V to neutral bar, and the converter and outlets work only when the microwave runs.
08-06-2021, 01:02 PM
Ray
So what do I do about it?
08-06-2021, 01:11 PM
The electrics worked perfectly until the original converter quit. I replaced it with another 55 amp converter. When I turned the power on, everything worked for a second, then there was a click and a huge cloud of white smoke billowed out of the cubbyhole where the converter was. Then nothing worked. Then I installed another new converter and the result is what I posted earlier.
08-06-2021, 01:30 PM
Always Learning
I'd test your 50amp outlet. Make sure it's putting power out properly.
https://www.myrv.us/electric/Pg/testing.htm
Typically the magic white smoke is let out of the converter when 240v is applied to one of the 50amp legs.
08-06-2021, 01:31 PM
Yep. You most likely have an open/loose neutral. That's what I was expecting.
Check the white wire which is your neutral. It is what keeps each side of your 50 amp RV at 120 volts. An open neutral can cause all kind of voltage fluctuations and weird things when you turn on loads like your microwave.
Start at the outlet at your house and make sure the white neutral wire is secure. Go inside the RV electric panel and do the same. If you don't find a problem there it can be in the shore power cord or RV inlet for the shore power cord.
Do this while the power is disconnected and house circuit breaker off. You also want to check the neutral in your house panel feeding the 50 amp outlet.
08-06-2021, 02:02 PM
Whoa! You should not have 120V between the breaker and ground. You need to disconnect from shore power immediately and get your Neutral wires straightened out.
2016 Salem 27RKSS
08-06-2021, 02:11 PM
I see that you replaced a converter and that is when all of this started. I think you have something miswired or something came loose while doing the converter change. If you are unsure of what it is, it would be a good idea to get some new eyes which are familiar with electricity on the system, they will likely see something which is not right.
The test of 120V to ground and 0V to neutral tells me there is a problem with neutral at a minimum.
(Previous) Coachmen Mirada Select 37RB
(Previous) Coachmen Freedom Express 246RKS
(Current)2022 Grand Design Reflection150 226RK
2022 F150 Powerboost Hybrid.
08-06-2021, 02:21 PM
There you go... your answer is right there.
You miswired something and now you need to find what burned off/up.
Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=86
08-06-2021, 02:57 PM
Yes you should have 120v to both ground and neutral, these are tied together at the main manel in the house.
The ground to neutral should be very close to zero
The OPs comment on zero volts to neutral confirms the suggestion of a neutral issue.
If the power inlet is near the converter I would start there then go to the camper panel. It could be anywhere though
08-06-2021, 04:24 PM
Agreed, that's exactly correct on the voltage measurements. My money is on the possibility that the original converter failed due to the open neutral but perhaps the owner was not there to see the failure.
This is exactly what a good, protecting EMS prevents.
Ray
08-06-2021, 04:50 PM
Sounds like your microwave circuit is wired in series with one side of the breaker panel,
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
