Old 05-29-2015, 08:08 AM   #21
craigster_mi's Avatar
Originally Posted by TURBS View Post
Attachment 78418Attachment 78419Attachment 78420
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "9 nights"
turbs,
did you use twist lock or just straight receptacle/plug? even though I bought the portable I'm thinking of moving it inside by cutting my supply wire and adding plug/receptacle
thx,
craig
2018 F150 Eco
2015 Rockwood Mini-Lite 2504S
craigster_mi is offline   Reply With Quote
Old 05-29-2015, 08:14 AM   #22
all this work makes me wonder if it would be simpler to just use the portable version. just my 2 cents
2015 Ram 2500 4x4 6.4l with 2015 Sandpiper 25RLS
Wife, myself and 2 furry kids
Mountndream is offline   Reply With Quote
Old 05-29-2015, 08:20 AM   #23
TURBS's Avatar
Originally Posted by craigster_mi View Post
turbs,
thx,
craig
I used 30 amp twist locks.
Bought them on ebay for cheap.
I just found a set of 4 for a guy on the forum for $30.00
Go to lowes or hardware store and they'll be $20.00 - $30.00 a piece!
TURBS
Old 05-29-2015, 08:20 AM   #24
TURBS's Avatar
Nope.
TURBS
Old 05-29-2015, 08:30 AM   #25
all that work is Beer time interrupted.
Old 05-29-2015, 08:33 AM   #26
TURBS's Avatar
Got me there!
Albeit my install was only about an hour.
Hardwired advantages.
1) no theft concerns.
2) in coach "status" display moniter.
3) in coach manual override.
TURBS
Old 05-29-2015, 08:41 AM   #27
in all honesty, if I had to do it over again, i would probably buy the 50 amp hardwire. However, I have the 30 amp portable and am not about to waste the money i already spent.
That and before I saw how easy it was, I was concerned about screwing up the wiring/ electricty/ frying something. DW would not be happy. It's lucky I lived through the whole "you put screws through my new camper" fiasco.
Old 05-29-2015, 08:44 AM   #28
TURBS's Avatar
I seen that "happen" once .
Only the screws went through the side of the "BOAT" !
TURBS
2011 32bhok Sabre
Old 05-29-2015, 08:48 AM   #29
I still have to find something cool with Vinyl to put over it.
Old 05-29-2015, 08:50 AM   #30
TURBS's Avatar
How about ;
1) bullet hole stickers?
2) sticker of a screw?
TURBS
2011 32bhok Sabre
Old 05-29-2015, 09:46 AM   #31
Left Coast
WELL, if you pull the incoming power out of the distribution center and install it to one side of the pi unit then buy a 3' piece to go from pi unit back to distribution center then you'll always have enough to wire back in if you remove the unit since you never cut the wire to begin with.
Think smarter not harder.
TURBS
House wire sucks......If you working folks would work more over-time, and pay more taxes, my SS might increase and I could afford 1.298 for some wire.
Old 05-29-2015, 11:30 AM   #32
Originally Posted by bob caldwell View Post
If you sell rv and want to keep the unit......then what?
I'm an Electrician by trade.. Those plugs are just another point of a possible bad connection .. I can remove the unit just as easily as I installed it,,
Like I said some people may want to go p&p..
Joe
meganjoe is offline   Reply With Quote
Old 05-29-2015, 09:50 PM   #33
If you like things dark at night, install the remote display in an enclosure (or in a room other than where you sleep). The remote has two switch settings: 1) normal on operation where the display rotates through voltage, current, frequency error code. 2) Off mode is the bypass mode and directly closes the input to output and displays "OFF". In either case, the display is bright and could be annoying at night. This is from someone that put a small piece of electrical tape over the amber light on the frig.
DRiveWell is offline   Reply With Quote
Old 05-29-2015, 10:39 PM   #34
Left Coast
How can you see it with your eyes closed?
