Originally Posted by jeepman71
The problem with the Yamaha generators is when I use the parallel cable to tie two 2000s together. I can use one and the bonding plug with no issues. When I parallel the two I get a reversed hot/neutral code. I could bypass this but I am kind of afraid to try it.
Sorry for all the PMs I just found your post.
Your getting reversed polarity, if both gens work independently, like you tried each one single hooked to your 5 er with the EMS, then I would say the problem has to be in your cable or the cable plugs/banana plugs on the gens.
When you hook up a single gen how are you doing it?
If you haven't tried yet, hook up a single gen using the parallel cable (not the 20 amp outlets on the gen). If that works swap the cable ends (unplug the parrellel cable and plug the other ends into the same generator). Do this for both gens and see what happens.
This would test the banana plugs as well as the cable since you know a single gen works but they dont work in combination.
