09-25-2020, 02:25 PM
Pulled pigtail off trailer
09-25-2020, 03:11 PM
thanks but the wires coming out of the trailer dont match the colors of the pigtail.
09-25-2020, 03:19 PM
7 wires. Decide which is ground on the trailer. Now move a 12v source to each wire see what lights up. RH stop light LH stop light, running lights, brakes apply. that's 4 of 7. you know the ground wire 5 found, see which goes to the battery 6 found, and the last is the Aux wire.
2019 F150 4X4 7050 GVWR 1903 payload
2018 Avenger 21RBS 7700 GVWR
09-25-2020, 03:38 PM
This is your best option. Wire colours aren’t necessarily standardized unfortunately.
2007 Rockwood 2701SS
1953 GMC 9314
1982 GoldWing Interstate
09-25-2020, 04:23 PM
Mike134 above
has the answer for you...
the color coding from etrailer dot com website allows you to ID which wire is which at the plug end...
is going to take a bit of work on your part, since the color-coded wires ripped out of the trailer harness...
it won't be that difficult to ID the wires... someone watch the lights while you jump 12 VDC to each individual wire, then mark the wire with a Sharpie pen with stripes, and corresponding sheet of paper... 3 stripes on the wire=left brake, 4 stripes on the wire=right turn, etc... Then mark that sheet with the corresponding color code of the wire from the pigtail using the etrailer picture.
2014 Shamrock 183
09-25-2020, 04:52 PM
What would we all do without etrailer? That place os great!
Bruce
09-25-2020, 09:26 PM
^^^^^^^^ x2. I may go ahead and order 1 of those. The connection with 3 or 4 wires in it is probably the ground. Find your hot wire on the trailer end and see what lights up on each wire and label it. Trailer cord is color coded as to where each wire goes. Good luck.
Always at home regardless of where we are
