Old 04-14-2024, 09:25 PM   #1
robertc68's Avatar
Rear tail lights and wiring
I had to remove my tail lights, last year for some repairs. My RV has (2) round 4-inch lights on each side. I am putting it back together. I used a voltmeter to figure out the wiring, because I didn't take good notes before disassembly. Is there a special way to wire the lights when you have 4 tail lights ? The left side works fine, but the right-side turn signal are out of sequence. The lights flash but not together. Thanks.
2012,365 Saq.Sierra
2004 F350 DWR.
robertc68 is offline   Reply With Quote
Old 04-14-2024, 10:10 PM   #2
bikendan's Avatar
It always helps if you posted the year, make and model number of your RV. We don't even know whether it's a motorhome or trailer.
Moved thread from the General Tech and Repair section to the Electrical and Charging Systems sub-forum since the OP's questions are specific to that sub-forum.
Old 04-15-2024, 05:42 AM   #3
robertc68's Avatar
Yes makes sense ,it’s a FR Sierra 2012,model 365 SAQ 5 th wheel.Thanks!
2012,365 Saq.Sierra
2004 F350 DWR.
Old 04-15-2024, 07:22 AM   #4
Kanadian Kamper
kenandterry's Avatar
Out of sequence…..that statement confuses me.
1. So, there’s 2 separate lights on each side?
2. Both left lights operate properly, both as running lights and turn signals?
The right lights…..one is bright, the other is dim? then they switch and the original bright light goes dim, and the original dim goes bright?
That would indicate the wrong wires to one lamp….swap them, or….
The bulb is forcefully inserted incorrectly and needs to be rotated 180 degrees.
Let us know.
Ken and Terry
kenandterry is offline   Reply With Quote
Old 04-17-2024, 07:40 PM   #5
Prolly have a ground not where it is supposed to go.
2019 F150 HDPP 4X4 3.5. 2500lb payload.
2018 Rockwood 2506
Half Ton Heavy is offline   Reply With Quote
Old 04-19-2024, 06:28 AM   #6
robertc68's Avatar
Update-The tail light housing had a bad ( corroded)ground.I was able to test both housings,one would work and the other wouldn’t.Thanks for the tips.
2012,365 Saq.Sierra
2004 F350 DWR.
light, wiring
