Originally Posted by JimV
I have a 2013 Sunseeker and want to replace the incandescent light bulbs with LED bulbs. The fixtures are pancake type lights that are used on the ceiling. My problem is I cannot get the old 921 bulbs out of the fixture. I have pulled them straight forward and they won’t budge. I am afraid if I use to much force I will break the bulb. If anyone has a trick or solution to remove the old bulbs I am open to suggestions. I have attach a photo of the fixture. Thanks for your concern.
It helps to wiggle them, both left-right and up-down while applying a pulling force.
There are a bunch of different LEDs with a 921-style base which have various different numbers of LED chips. We like it bright and favor the style below. They come with socket adapters for all common sockets. They come with an adhesive foam back, but if you are applying them to a concave-dished fixture it helps to apply another layer or two of double-faced foam adhesive.
