Originally Posted by dnicoll
But, if the battery was connected reverse polarity - wouldn’t the reverse polarity fuses blow? Typically (I think?) two fuses in the fuse panel and a battery installed reverse polarity would take out both fuses? In which case nothing would work.
The reverse polarity fuses probably would blow but the slide motor is wired directly to the battery. Not having a 5th wheel I don't have landing
gear but my electric tongue jack is also wired directly to the battery.
Those circuits are protected against overload by a Type I circuit breaker at the junction box under the frame of the trailer. It's not affected by the direction of current flow.
I cannot explain why the lights would remain on. Maybe that has something to do with current flowing backwards through a neutral line, bypassing a fuse? Dunno.
TV: 2021 Ford F-150 4WD XLT Crew w/ 3.5L EB & HDPP, payload: 2,416#.
Camping nights: 2021, 52; 2022, 99; 2023, 88; 2024, TBD (Est: 80+)
