Neat thread, I'm doing similar upgrades to my 2509S.
This is the 3rd camper I've done solar/inverter setups on and I've had pretty good luck with budget minded components.
My set up is:
4-GC-2 6V from Costco, I believe 464ah
4 - 100watt flexible panels wired in series/parallel (24v nominal)
Victron Smartsolar MPPT 150/35 charge controller
Victron BMV-700 battery monitor
PowerTechOn 2000 watt pure sine wave inverter
Manual transfer switch using a C3 controls 6 pole dpdt switch as outlined in this thread:
http://www.forestriverforums.com/for...ion-18389.html
I boondock 95% of the time, and the solar will take care of the charging, so I'm not worried about getting an inverter/charger, so I just went with an inexpensive pure sine wave inverter that got decent reviews.
I like the manual transfer switch because it removes the A/C, water heater, converter and 120v side of the fridge out of the loop when on inverter with no need to flip breakers or install a sub panel. I plug in to shore power so rarely, it won't bother me to have to manually flip a switch to do so. I'll leave it in inverter mode 95% of the time.
I really like the look of those lithium ion batteries, but at this time, they are way out of my price range. With all of the components listed above I'm well under $2,000 even with all the wiring. They say by 2025 battery prices should cut in half though, so maybe they will be in my future! Would sure like that, as right now I'm carrying around more than 200lbs of batteries!
I have the batteries and the BMV-700 installed, all the other parts are either in or on the way, so once we get some nice weather and some time on the weekends I'll get to installing everything!
