Roof airs, 12volt exhaust fans, and furnace issues
My roof airs and furnace, and both 12 roof exhaust fans run for a while then shut off for several hours, then come back on. I've replaced house batteries, and tested converter and it putting out 13.5 volts. The batteries are reading 13.26 volts. Any suggestions on things to check. I know a little but not alot about dc.
None of these items should run unless switched on.
Fully charged battery will be 12.7vDC, not 13.2vDC which is the output of a battery charger. Disconnect the battery from the charger, let it sit overnight, and measure the battery (only) battery the next day. Internally shorted battery (AKA dead) sometimes give strange voltage readings.
-- Chuck
Welcome to the forum its a great place to get your questions answered. It would help to know what rig you have Year, model, Mfg. I think I would start be doing a load test on each battery. If you don't have a load tester most auto parts stores can do this for you. charge your battery with a stand alone charger disconnected from the rig then load test. JMHO
Retired Navy
2016 Flagstaff 26 FKWS
