Good luck!
No brake lights probably means no brakes either!
No lights at all could be a bad umbilical cord, bad connections at the trailer, or the outlet on the truck. Easy to check the truck with a multimeter. Ignition has to be on with my Fords for any signals to be sent to the trailer.
Amazon can have a trailer connection tester on your front porch tomorrow. Prices range from $11 and up.
If the truck is not good check fuses and relays there.
If the truck is good trace the umbilical cord back to the trailer where there should be a junction box for the connections. With the cord plugged in you can check for power here. Replacement cords are available. Don't get too long or it will drag; too short can pull out from truck.
-- Chuck
