04-03-2021, 07:40 AM
#21
Originally Posted by cboss
I have this and it works perfectly. Nice clean device.
Let’s go camping!
04-03-2021, 07:54 AM
#22
Originally Posted by 1l243
I did this to a Toy Hauler I had a few years ago. I wanted it for added security. Kinda nice if you hear something outside to to be able to click on all the exterior lights. I added a lighted 12 volt switch to the inside of the trailer. Easy to do a power source and find a wire to the clearance lights somewhere nearby and tap into it. A fused relay would be a nice touch.
That sounds great but definitely above my skill level
Carmen and the pack
2015 Coachmen Clipper 17BH
2017 Dodge Durango Citadel 5.7 Hemi
04-03-2021, 07:55 AM
#23
Originally Posted by chriscowles
In normal operation, fuses to the running lights are in the vehicle. There are none in the trailer. The fuse trick is inherently protected against a short. Unless it incorporates a fuse, the device from Amazon is not.
Good point! Does anyone know if the Liteswich is fused?
Carmen and the pack
04-03-2021, 11:46 AM
#24
That's true unless like in my case the truck is not usually attached when camping and I'm running a separate hot wire to the switch from the battery that I want fused. Plus being that I'm turning on about 15 lights at once a relay is a good idea.
04-03-2021, 07:55 PM
#25
You guys are starting to cause me to run low on funds. I find this as a must have. I just bought one direct from the manufacturer. Luckily they are just down the road from me here in Wisconsin so I should have mine pretty quick...
https://www.liteswich.com
04-03-2021, 08:07 PM
#26
For $7 and 2 inches of wire you could make your own?
7 Way Blade Connector Socket
You can even incorporate a fuse.
TV: 2021 Ford F-150 4WD XLT Crew w/ 3.5L EB & HDPP, payload: 2,416#.
Camping nights: 2021, 52; 2022, 99; 2023, 88; 2024, TBD (Est: 80+)
04-03-2021, 08:37 PM
#27
I just can't justify paying $30 for something a 25 cent fuse will do.
04-03-2021, 09:06 PM
#28
True but I like to have things look neat. I spent several thousand on the trailer and figured $30 is a drop in the bucket, a mere fraction for an apparently quality built product. I don't have any affiliation with the company or product,, just really liked what I saw. I run into the same thing with the motorcycle I like to ride as well as other brands. Guys spend 10's of thousands on the bike and then cheap out on things like the oil filter.
I also asked directly about it being fused as this came up in the discussion. The manufacturer just responded that it is indeed fused.
04-03-2021, 09:09 PM
#29
A response directly from manufacturer is yes.
04-03-2021, 09:17 PM
#30
Awesome, thanks!
I know there are cheaper ways but I agree with you, I like things done just so. And the switch is bonus, no wrestling with the plug!
Carmen and the pack
04-04-2021, 03:25 PM
#31
I thought I saw a plug connection that was already wired on Amazon.
Almost like taking plug adapter (wires or pigtail) from RV, jumping the pins, and plugging it into your camperRV.
It was something like $10. I can not find it now. Has anyone else seen one.
It was different than https://www.amazon.com/Camper-LITESW.../dp/B075JP5C8C
04-04-2021, 05:25 PM
#32
Blog: RVroadtripper.com
Instead of a fuse, use a flasher (motorcycle supply stores carry them as does Autozone). Say for instance you have to pull off the side of the road at night and you need to drop your trailer to go get parts or help, the flasher will flash your trailer lights.
Maxxis 235/80/16E; AirBags w/AirLift1; mor/Ryde Rubber Pinbox; Andersen UltimateII Alum. 5erhitch on Reese Flipball w/Curt 4" offset; LCI Ground Control3; King Dishtailgater; Traveling with 10' Portabote;
04-04-2021, 05:29 PM
#33
Can you post a link? Not sure what to look for and sounds like it it a good thing to have. Lol for emergencies, not for at the campground. I can’t even imagine that! 🤣
Carmen and the pack
04-04-2021, 08:48 PM
#34
Can you post a link? Not sure what to look for and sounds like it it a good thing to have. Lol for emergencies, not for at the campground. I can’t even imagine that! [emoji1787]
04-05-2021, 08:19 AM
#35
Here is a small inexpensive item at amazon for less than $20. Just plug it onto the cord end instead of using that fuse.
https://www.amazon.com/AP-Products-0...a-568069456289
It is available on eBay too for less than $15
https://www.ebay.com/itm/39276793861...BoCA6QQAvD_BwE
Personally, we have found a mini fuse, plugged in above the two prongs, works perfectly for us.
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
04-05-2021, 09:10 AM
#36
i skimmed the patent, and found nop mention of one, however i would think given the light duty rating of the pushbutton switch they use (i would assume the switch is rated at MAYBE 20a) it would act as a fuse if there were an issue?
