Old 03-25-2020, 02:23 PM   #1
RV power cord
Greetings. I am going to answer my own question. Pros and cons on RV power cord. Mine is the pull out. Thinking of changing to a twist lock. It works great no problems. Why change, I haven't a clue!?! Not to be like every other. Don't know. Other than minus a few $$ and change. Would be my guess. Answered my own question. Thanks. Be safe . Have a good day!!
DVDim is offline   Reply With Quote
Old 03-25-2020, 02:34 PM   #2
SailorSam20500's Avatar
If you do make the change, rather than a twist lock connection on your RV, seriously consider using a SmartPlug. Saw them at a Mike Sokol presentation. All round a better setup.
https://smartplug.com/rv/
Al
Save the Earth. Itís the only known planet with Beer.
There are times where my greatest accomplishment is keeping my mouth shut...
S.E. Mich. Flagstaff 26FKWS / 2019 F-150 3.5 EcoBoost SCrew Propride
SailorSam20500 is offline   Reply With Quote
Old 03-25-2020, 02:42 PM   #3
Oaklevel's Avatar
There are times that I miss our pull out type. Both have their Pros and Cons.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 03-25-2020, 03:18 PM   #4
TechnoRV has some great videos on the installation of the SmartPlug. I really like how the connection is made.
Pat, WW9R
2020 Rockwood Ultra Lite 2614BS
2019 Ford F-250 Superduty XLT, Crew cab, long box, 6.7L Diesel, 3.55 Gears
ProPride P3 Hitch with 1400 lbs bars
Haloview rear and side view cameras
PatHoppe is offline   Reply With Quote
Old 03-25-2020, 04:24 PM   #5
If it works and isn't giving you problems, why change. Sometimes change brings it's own issues. Not necessarily from the different type but the actual act of changing it.
"A wise man can change his mind. A fool never will."
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 03-25-2020, 08:50 PM   #6
Our old unit had a twist lock and a separate cord. The new unit has a pull out cord that sofar I like way better. I donít have to find a place to store the cord and I only have to pull out what I need. Sure you need to wipe it off as you put it back but I had to clean the separate cord before I put it in a tote. I have wiped down air hoses in the shop for 40 years,this is no different. Jay
2016 Rockwood 2504s.
TV: 2014 Silverado 1500 double cab.
Jay2504 is offline   Reply With Quote
Old 03-25-2020, 09:37 PM   #7
Thanks for the replies. I have had 4 or so RVs ,5ers, TTs all had pull out cords. No problem with storage, no other problems either. I answered my own question and you fine people had your helpful say. Guess I am bored with this virus stay home stuff. Are we going to get any camping in 5he coming year? Thanks have a good day
Old 03-26-2020, 08:48 AM   #8
Head Rambler
Just to inject an opposing opinion (and you know what they're like )!
Our RV came with a pull out cable and I hated it. So I changed the service to 50 amps and also changed the pull-out cable to a plug and receptacle. I like having a dis-connectable cable. The major things I dislike about the pull out cables are;
1) It gets really stiff in cold weather and is hard to push back in the cubbie.
2) If you have to put it away in the rain it's a real pain, whereas I can just disconnect ours and throw it in the back of the truck until I get somewhere dry to clean it up.
3) And a third thing for me is that I have a 30' 30 amp male to 50 amp female adapter cable that I can use if I don't need 50 amp service, that way I don't have to handle the 50 amp cordset
Like I said, that's just my opinion!
Gotta go campin!
Old 03-26-2020, 09:20 AM   #9
I concur on all points!
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
CedarCreekWoody is offline   Reply With Quote
Old 03-26-2020, 10:16 AM   #10
SeaDog's Avatar
My cord is the twist type, I have two extensions the have the standard RV plugs. I left for Hells Canyon know I was hooking up so only took one cord. As luck would have it I grabbed the non-twist so I couldn't hook to my rig. Just something to think about
Retired Navy
2016 Flagstaff 26 FKWS
Old 03-26-2020, 10:44 AM   #11
I like the removable twist lock because of the adapters and shorter cables I can use with them. At home, I have a short pigtail adapter for 30amp to 15/20amp and can use the shortest 12awg cable I have to plug it into the garage.
2019 Cherokee Wolf Pup 16BHS
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package
Husky Centerline TS WDH 400-600# spring bars
Boomerweps is offline   Reply With Quote
Old 03-28-2020, 11:07 AM   #12
RiderBloke
RiderBloke's Avatar
Smart Plug
I would change to the Smart Plug system if they had a right angled smart plug ie. with the cord coming out the bottom (pointed at the ground), as I believe this would put less stress on the plug and keep the cord closer to the rig. Just my thought.
Retired Intentional Interim Minister
Member of the BMW MOA
Saginaw Valley BMW Riders
RiderBloke is offline   Reply With Quote
power
