Old 02-08-2020, 11:44 AM   #1
RV PV shaded by A/C or Vent cover? Anyone?
Has anyone with multiple solar panels on their RV roof experienced significant decline in solar power because the A/C / Maxxair/ antenna /etc was partially shading a panel??
2019 Cruiser Stryker 2613
2019 F 350 6.2 CCSB 4.3
14k Equalizer
400w of solar on roof
Deanm is offline   Reply With Quote
Old 02-08-2020, 12:24 PM   #2
Shading of PV panels by any obstruction will reduce the output of any panel.
Fundamentally a PV cell produces ~ 0.5 VDC. Amperage comes from the area of the cell and the amount of light the cell can "capture". Therefore, the fewer photons the cell can capture the less power it will produce since voltage is a constant.
The combination of series and parallel circuits on a single panel will determine how well it handles partial shading. However, you need to keep the voltage up to maximize efficiency of your solar system. It is a balancing act the panel manufacturers have to do. You can also wire your panels in the series/parallel combination to do the same thing.
Hobienick
2020 Rockwood Roo 19
2012 F150 SuperCrew Ecoboost
hobienick is offline   Reply With Quote
Old 02-08-2020, 06:34 PM   #3
rk06382's Avatar
Shading is why I have my panels in parallel.
Robert
2018 FR3 28DS | Boondock 90% of the time
Samlex EVO-3012 Inverter/Charger | 600ah Battle Born LiFePO4 | Victron BMV-712 & MPPT 100/50 | 800W Renogy Solar | Fan-Tastic Fans | Blue Ox TruCenter | SnapPads | SumoSprings | Koni Shocks
Solar Power & Battle Born batteries
rk06382 is online now   Reply With Quote
cover, vent
