Originally Posted by DonnaJ65807
Yes, that is exactly what my electrician cousin told me probably happened. Luckily I had a spare 3 amp fuse and everything is working once again! But in defense of my friend that snipped the wires, he saved me a 10 day camping trip of having the alarm beeping lol
Glad you have the issue resolved.
As to your friend, what do you think would have happened if that had been a 120-volt line? You could be attending his funeral. Otherwise, one should know simply removing the 12-volt fuse would have stopped the alert beeping. He is definitely a (b) type!
TO ALL RV'ers, and I say again. You must know where every fuse and circuit breaker is located and what each one controls. And more importantly, know what systems are protected by the fuses and what systems are protected by circuit breakers. That's everything both 12 volts and 120 volts.
I boldly will say, if you don't know this information, then keep your rig in the dang driveway.
Bob
