Old 03-30-2016, 10:41 AM   #1
3hbenz's Avatar
Salem hemisphere 300bh. Please help with electrical issue
We had a salem for 13 years and We recently purchased a new Salem hemisphere 300BH. I plugged an electric skillet into the outlet by the refrigerator, the refrigerator and the outlet both quit working. This happened in our old camper to and we always checked the fuse the breaker box and the GFI and could always get it working. For this new camper we have checked the fuses, GFI and checked the breakers and it still doesn't work. We have left the breakers off for a while, but still doesn't work. 3 weeks later, still nothing. Does anybody have an idea of what we can do to fix this? We got it set up on our lake lot so we really don't Want to have to take it three hours back to camping world to have it checked out. Thank you
3hbenz is offline   Reply With Quote
Old 03-30-2016, 11:09 AM   #2
Look around for a GFI outlet (outlet with a couple small reset buttons on the front) and press the reset button. Many outlets can be connected in series to one GFI outlet.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 220 AH Battery Bank (Two-GC2) - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre with Tow Package
Boon Docking 99% of the time.
boondocking is offline   Reply With Quote
Old 03-30-2016, 11:11 AM   #3
3hbenz's Avatar
We check the one in the bathroom could there be one behind the refrigerator, it's just a regular house refrigerator
Old 03-30-2016, 11:41 AM   #4
I doubt there is a GFI behind the fridge, but check anyway. Also when you checked the breakers did you click them to the off position then back on again ? Sometimes when they are tripped they don't look like it.
2007 Surveyor SV230
Old 03-30-2016, 11:48 AM   #5
3hbenz's Avatar
Ok, we will check. Yes we clicked them off and still nothing. Thank you. Soundslike we may have to take it in.
Old 03-30-2016, 12:14 PM   #6
I would turn off all breakers and 1 by 1 turn them on and check all outlets and devices that run off of ac power. Go 1 breaker at a time and see if any other outlets or appliances are also not working. This would include outside outlets, outdoor kitchens, and also since you stated it is a residential fridge do you have an inverter? If so have you checked that?
Eastlake, Ohio
2013 F-350 Turbo Diesel
2016 Heritage Glen 368rlbh
Dinostop is offline   Reply With Quote
Old 03-30-2016, 01:51 PM   #7
3hbenz's Avatar
Thank you Dinostop, I will try that. What would I need to check on the inverter? This is our first camper with one.
Old 03-30-2016, 06:14 PM   #8
My inverter has a fuse in it. Not sure if that would blow or cause an issue if on shore power if it was blown or not. Also not sure if the inverter is tied into a gfci as well or not. As for the breakers don't trust the factory labeling. Mine has a label for a washer and dryer but I opted out of that package when I ordered mine from the factory.
Eastlake, Ohio
Old 03-30-2016, 07:14 PM   #9
3hbenz's Avatar
Thank You so much! We will try this. I hope it works. I really appreciate the information!!!
Old 03-30-2016, 07:30 PM   #10
CampingGator's Avatar
Is your whole unit not got electricity or is it just that one circuit? We have had it blow the campground electric pedestal box and the campground had to come out and replace the breaker in that box. Just a thought from an ignorant female.
_____________________________________________
2010 Ford F-150 Crew Cab
2015 Salem Hemisphere 263RL
CampingGator is offline   Reply With Quote
Old 03-31-2016, 08:31 AM   #11
Also, have you looked at every receptacle in and around the RV for GFCI's? Ours has one on the outside under the awning and one inside in the bath.
If that doesn't solve the problem, I'd start pulling the receptacles to see if there was a wire that came lose behind one of them. I've seen that happen before.
Gotta go campin!
Old 03-31-2016, 08:50 AM   #12
TURBS's Avatar
Isn't there a gfci in the kitchen as well?
2008 2500hd Duramax
2015 Columbus 320RS
2016 nights camped "0"
2015 nights camped "34"
Old 03-31-2016, 01:40 PM   #13
Do you have an outdoor kitchen with a gfi? I have gfi outlets inside and out.
Lowes48fan1 is offline   Reply With Quote
Old 03-31-2016, 07:51 PM   #14
3hbenz's Avatar
It's just that one circuit.
Old 03-31-2016, 07:53 PM   #15
3hbenz's Avatar
Yes, we have an outdoor kitchen but there's no GFCI there.
Old 03-31-2016, 07:54 PM   #16
3hbenz's Avatar
We have checked in and around, when you say pull the receptacles and check the wires, do you mean behind the fuses or behind the breakers?
Old 03-31-2016, 07:55 PM   #17
3hbenz's Avatar
2008 2500hd Duramax
2015 Columbus 320RS
We couldn't find a GFCI in the kitchen.
Old 03-31-2016, 07:57 PM   #18
3hbenz's Avatar
Old 03-31-2016, 08:25 PM   #19
TURBS's Avatar
Look under the top mount cabinets. [emoji849]
Old 04-01-2016, 06:48 AM   #20
I meant the actual receptacles themselves. It wouldn't be a bad idea to look at the terminal screw on the breaker either as it could be loose.
Gotta go campin!
electric, electrical, salem
