Old 09-19-2020, 04:50 PM   #1
Seven pin trailer connector 12vdc power
I realized that my rv trailer batteries are not charging from my tow vehicle. I looked up the wiring and found the 12vdc power terminal is at about one o'clock, and the ground is at about seven o'clock on the truck. With the truck running I do not get any power between the 12vdc terminal and ground. I'm figuring I should have power at this time. I checked my fuses and they check out as being good. I also pulled the plug from under the truck and checked those terminals, and get the same results. All the trailer lights and brake work perfectly.
Any ideas on where to go from here???
chengdave is offline   Reply With Quote
Old 09-19-2020, 05:09 PM   #2
Iggy's Avatar
Open up the trailer plug and see if you have any wire off the 12vdc hot. (4)
Probably the trailer wasn't wired for it.
Lights, brakes are all seperate fromthe 12 volt for charging.
Here is the 7 pin layout for a typical trailer.
2012 Georgetown XL 378TS (Large box with wheels) 76,100 miles
Old 09-19-2020, 06:56 PM   #3
I used a similar chart to find which terminal was hot.....but it's not....no voltage....
Old 09-19-2020, 07:18 PM   #4
If your truck is a Ford please let us know.
Include if it's a pushbutton start, there are several hoops you must jump though get power at that 12V terminal.
2019 F150 4X4 7050 GVWR 1903 payload
2018 Avenger 21RBS 7700 GVWR
Mike134 is offline   Reply With Quote
Old 09-19-2020, 07:31 PM   #5
bikendan's Avatar
Yea, it's always helpful if posted year, make and model of truck and trailer, since you don't have any of that information in your profile.
Equalizer WDH
Old 09-19-2020, 07:39 PM   #6
I have a new F350 - interested in hearing about this.
覧覧覧覧覧覧覧覧覧覧覧覧-
2021 Silverback 29RW - 2020 F350 Powerstroke
覧覧覧覧覧覧覧覧覧覧覧覧-
Tokenwiz is offline   Reply With Quote
Old 09-19-2020, 07:39 PM   #7
Yes...sorry...you're absolutely right. 2014 Ram 4x4 1500. I'm not sure when it quit working as we drove it to Alaska pulling a trailer a couple years ago and it worked fine then...then traded in the trailer on a motorhome and I didn't tow during that time. This year, we are towing a new trailer, but until last week always had ac power on site. This week we did some dry camping and found the batteries weren't charging betwen sites at all....
Old 09-19-2020, 07:59 PM   #8
Sorry can't offer any help for a Ram.
The Ford 12V charge line doesn't work unless you have a trailer connected, truck running, press the brake pedal for about 3 seconds and have all the doors fully closed. And if it's a push button start leave the fob inside the running truck.
Old 09-19-2020, 08:04 PM   #9
Thanks Mike - appreciate the info.
覧覧覧覧覧覧覧覧覧覧覧覧-
覧覧覧覧覧覧覧覧覧覧覧覧-
Old 09-19-2020, 08:11 PM   #10
bikendan's Avatar
Your Ram, if operating correctly, will only provide a trickle charge at best while driving. So if the battery was discharged before moving to another dry camp spot, unless you drove 8-12 hours, the battery was probably never fully recharged.
You should have the battery fully recharged and then load tested or hydrometer tested.
Then deal with why your truck is not providing power through the charge wire.
Equalizer WDH
Old 09-19-2020, 08:44 PM   #11
Thanks..I will check with a better voltmter when I get home....
Old 09-20-2020, 03:39 PM   #12
SetauketJeff's Avatar
For Chevy Owners:
FYI for Chevy owners: Some of the Chevys, even the ones with towing packages do not come with pin 4 connected (12V Aux). You need to go under the hood and find the lead with the loop connector buried in the wiring harness next to your fuse box. Remove the lead and connect it to one of the external hot terminals using your own nut (remove fuse box cover to expose your hot leads).
Every stop light is a staging light!
2021 Wolf Pup 16FQ.
2007 Chevy Trailblazer LT 157K Just pulled 16FQ 1,044 miles.
2004 Ford F-150 STX 206K Will use to pull 16FQ in sand.
SetauketJeff is offline   Reply With Quote
Old 09-20-2020, 03:49 PM   #13
Head Rambler
On your Ram the trailer tow fuses are F28, F29 & F30 in the underhood fuse box. F30 is a mini fuse. Be sure to test all those.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 09-20-2020, 04:44 PM   #14
Thank you! I'll have another looksee!!!
Old 09-21-2020, 05:05 AM   #15
I didn't find out for over 7 or 8 years that my 2008 2500 GMC Sierra D/A wasn't charging either. My trailer repair guy fixed the issue right away as he knew exactly what to do.
Mike K
2019 Cedar Creek 34RL2 w/disc brakes
2017 GMC 3500 D/A, DRW, 40Gal Aux Tank
USN 76-82
Retired Dept of Navy: Navy/USMC Flt Test Engineer
Splashes3 is offline   Reply With Quote
Old 09-21-2020, 05:24 AM   #16
DouglasReid's Avatar
It would be more helpful if you could tell us what he did to fix the problem.
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 09-21-2020, 10:10 PM   #17
See my post above. Chevy, GM are the same.
2021 Wolf Pup 16FQ.
Old 09-21-2020, 10:18 PM   #18
Mr. Dan's Avatar
You mean "Chevy, GMC", right? Are you sure that's what Splashes3's repair guy did or was there another issue?
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 = 94; booked = 14
Old 09-21-2020, 10:55 PM   #19
Current GM auto brands are Buick,Cadillac, Chevrolet, GMC, Holden and Wuling. Former GM automotive brands include La Salle, McLaughlin, Oakland, Oldsmobile, Opel, Pontiac, Hummer, Saab, Saturn and Vauxhall and Daewoo.
99% sure. They don't come hooked up and if you don't test pin 4, you'll never realize it. I'm actually considering putting a switch on mine. So when I'm not "trailering" there's less chance of shorts should the 7 pin outlet get wet.
BTW: If you use a wireless brake controller, pin 4 is what powers it.
2021 Wolf Pup 16FQ.
Old 09-23-2020, 11:05 AM   #20
I checked my voltage with a good multimeter (Fluke 77) when I got home. I'm getting 4vdc without a load on the 12vdc terminal of my 7 blade truck trailer connector. I thought charging rate was according to amperage, not voltage. But then I never claimed to be an electrician.
What say ye???
PS: I did check my fuses, and all tested good. There's actually five fuses....including F53 and F81.
power, trailer
