Originally Posted by coloradojoe13
There is a circuit breaker panel next to the fuses, but they were all on. It appears the unit does have a converter. Could the problem be that I had it plugged in to a 15A circuit from my garage? Also, is there any other place to look for a main 120v breaker switch?
When plugged into shore power do the 120 volt receptacles, A/C, Microwave, work? If so then 120 volt shore power is getting to the unit.
If they work, don't worry about the 120 volt power, concentrate on the 12 volt power.
It appears that the lights now don't work on either battery or shore power?
If that's the case then the first thing to do is make sure that the 120 volt breaker labeled Conv or converter is on. Then make sure that the reverse polarity fuses at the converter are good. Then look for the resettable fuse near the battery. I suspect that you have a couple of issues to find.
