Maybe yes, maybe no.
Might want to contact the manufacturer of the generators you are wanting to "parallel".
Then again, if your inverter generator has provisions for parallel connection, why not use THEIR setup? Most are in the same price range.
This appears to be for a select number of Westinghouse units.
