Old 08-07-2022, 09:48 PM   #1
Slide out doesn't work
We have 2013 Rockwood Roo 23ss. My son borrowed it and one morning the wires to the battery were burnt! Was plugged into hydro at the time. He immediately disconnected battery. When he attempted to put the motorized slide out in it wouldn't work. Checked fuses etc. Are there more fuses underneath? We did reset the small converter underneath by the tongue.
Gcreed is offline   Reply With Quote
Old 08-07-2022, 11:03 PM   #2
bikendan's Avatar
Originally Posted by Gcreed View Post
We have 2013 forest river 23s. My son borrowed it and one morning the wires to the battery were burnt! Was plugged into hydro at the time. He immediately disconnected battery. When he attempted to put the motorized slide out in it wouldn't work. Checked fuses etc. Are there more fuses underneath? We did reset the small converter underneath by the tongue.
It would help if posted the brand of the RV. Forest River is the corporate name, not the actual brand name.
Also are you sure that 23S is the correct model number?
I know of a Rockwood Roo/Flagstaff Shamrock 23SS or 233S.
What "converter" is under the tongue? The only converter is inside the RV, usually behind the fuse/breaker panel.
Moved thread to the Electrical and Charging System sub-forum.
Old 08-08-2022, 06:28 AM   #3
Oaklevel's Avatar
We need a little more information. Model and Make of RV. I assume to you hydo means electric? Hydro in the states usually means water.
What are you plugged into a campground pedistal, at home, or other?
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 08-08-2022, 06:46 AM   #4
Yes in this context hydro means electricity, hydroelectric power.
-2017 Isata 5 35DB (bunkhouse)
#teambunkhouse
Phreak480 is offline   Reply With Quote
Old 08-08-2022, 07:14 AM   #5
slide may require a battery be connected
as the converter may not supply enough amps to power high demand loads such as motors for slides and stabilizers
There are a ton of results when I googled ..... burnt battery cables rv
looks like a common problem
https://www.google.com/search?client...tery+cables+rv
Tarpon Springs FL
2022 Salem 24RLXL
Aussieguy is offline   Reply With Quote
Old 08-08-2022, 08:04 AM   #6
Hello yes sorry the model is rockwood roo 23ss. We reset the auto breaker underneath.
Old 08-08-2022, 08:07 AM   #7
Hi. Rockwood roo 23ss. Was plugged into camp pedestal , hand cranked slide out in to get home. We connected to electrical at home still no power to slide out. Everything else works. Could a short on the slide out motor have caused the burnt wires leading to the battery? Battery seems fine.
Old 08-08-2022, 08:42 AM   #8
you really need to talk more with your son and try and determine if he was using anything....
did he notice anything out of the ordinary?
slide was moving real slow and he kept holding switch down
PS I always have the trailer hooked up to truck with engine running OR hooked up to 120v pole before I move my slides
you will have to do some research on electrical trouble shooting
get a multi meter and learn how to use it
LOTS of videos on youtube already or learning
google these phrases
how to use multi meter
how to check a motor with multi meter
Tarpon Springs FL
2022 Salem 24RLXL
Old 08-08-2022, 08:57 AM   #9
Hello. Thanks! Apparently when he put the slide-out out it was really slow..and the ground fault outlet tripped a few times during the week. I suspect the power at the park was faulty and he didn't realize having never camped before. We are testing the motor today....
Old 08-08-2022, 09:03 AM   #10
Is the battery re-connected and charged ?
that slide motor is 12v and needs a good battery
make sure Burnt cables are still in operable condition
and all connections to battery are clean
anything else in the trailer NOW... not working since this issue ?
Tarpon Springs FL
2022 Salem 24RLXL
Old 08-08-2022, 01:33 PM   #11
bikendan's Avatar
I had a Roo 23SS and there's a separate fuse underneath the chassis, for the slideout. It was along the chassis, on the slideout side. Mine blew it one time.
Old 08-08-2022, 01:37 PM   #12
Hello again. We had the motor tested and the coil is fried. We are assuming that is what caused the wires to also burn. Hopefully a new motor won't bankrupt us!!
Old 08-08-2022, 09:33 PM   #13
New motor for slide out
This is for 2013 rockwood roo 23ss. Can't find any specs on which motor we need for slide out. Have checked with one dealer so far and they couldn't find it either. Anyone have a part number or any info.? Thanks
Old 08-09-2022, 12:07 AM   #14
VENTURE MFG ACTUATOR SLIDE-OUT 18:1 MOTOR: nwrvsupply.com
https://www.etrailer.com/question-338236.html
https://pdxrvwholesale.com/products/...otor-8910-81ah
It appears that the motor itself is not sold separate from the gear box. Looks like you can get the motor and gearbox separate from the actuator arm or with the arm.
The issue I see in my short search is that only a 5800 rpm motor and a higher speed 9100 rpm motor seem to be the options.
Maybe time to make some calls to Lippert or Forest River customer service?
The part number from your picture is 8532-18ht. It's a 12V 9500 rpm motor manufactured date May 15 2012. Unfortunately, this does not cross reference very well. Probably because they sell these with the gearbox and the part number for the assembly is different. There may be a number on the gear box that may cross reference better?
2020 Rockwood 2104S
2019 Ram 2500 Crew 4x4 6.7 cummins
theHookers is offline   Reply With Quote
Old 08-09-2022, 06:56 AM   #15
see if you can find a local company that repairs altrernators / starters
they may be able to rewind the motor and replace the bearings
PS... an electric screw driver with a long driver bit can be used to open close until it gets repaired
Tarpon Springs FL
2022 Salem 24RLXL
Old 08-09-2022, 07:31 AM   #16
Thank you that is very helpful. We have a couple dealers locally that are getting us quotes.
Old 08-09-2022, 07:32 AM   #17
Thank you. Good idea. We'll definitely investigate that option.
Old 08-15-2022, 10:38 PM   #18
Had the same thing happen. 30A fuse under the trailer. Follow the wires from the slide motor to the front where the batteries are, should be something there that looks line a small block. Pop the cover off and there's your fuse.
UrbanAngelRVer is offline   Reply With Quote
Old 08-16-2022, 07:41 PM   #20
Two different gear ratios and two different motor speeds available. Best to pull existing motor/gearbox before ordering.
Avoid at all costs the cheap Chinese ones on Amazon. They're cheap because they don't have torque limiting clutches in the main gear. Hit the stop in or out and instant broken gear.
I tried one and it went back to Amazon the next day.
2004 Nissan Titan
TitanMike is offline   Reply With Quote
slide, slide out
