Originally Posted by Outsider
Anyone have any idea if the new 24VDC units actually draw less current over time than the previous 12VDC units. This is out first CPAP so I have nothing to compare to.
If we have to keep this 24VDC unit what setup would use the least amount of battery in the long run when dry camping? (12V to 24V adapter straight from the battery perhaps?) As I mentioned earlier we do about 50% boon docking/dry camping. I already plan to add 2 GC2 batteries and will probably have to boost my solar panel as well (have 100W on top from the factory and may add about a 200W portable with charge/controller to the side mount solar port).
Thanks.
It all boils down to wattage. 120 watt appliance (just to use this as an example) will draw 240 watts on 12 volts which converts to 20 amps plus whatever overhead of the inverter. If your inverter is powered by 24 volts then it only will draw 10 amps plus inverter overhead. Still the same wattage output with the difference being the input voltage/current to the inverter.
Rather than look at the voltage of the CPAP unit, look at the wattage then divide it by 12.5 to see how many amps it will draw whether through direct connection if 12 volt or through an inverter if a 24 volt unit.
Once again, think watts as they will be the same at 12, 24, or 120 volts.
As said earlier, connecting directly without adapters or Inverters is the most efficient.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
