Best way to know is to find the model of your Converter and go to the manufacturer of the converter's website. Even if someone with the same trailer checks in, it's possible that in a 14 year old TT the converter has been changed.
Converter can be either in the lower half of the Power Distribution Center or mounted separately (a deck mount).
If you open the door of your Power Center, where you access circuit breakers and fuses, there should be a model number. You can look that up and the mfr's website should tell you if it's "smart" or not.
