Old 05-23-2020, 09:30 AM   #1
Soaking a 7-way plug in vinegar
I read that you can soak a 7-way plug in vinegar to remove the corrosion from the terminals inside the connector.
,, is it safe to do that while my travel trailer is plugged into 50 amp on the AC side and connected to my 12 volt battery also? Or do I have to go back underneath my trailer and disconnect the 7-way wire somewhere first?
Judd is offline   Reply With Quote
Old 05-23-2020, 09:36 AM   #2
FLY4FUN
...don't believe I would. I'm unsure of just how much the vinegar might support conductivity, but expect it will. That said, it seems likely that there'd be some potential for "shorting" that could damage converter. Without a lot of research, the only way I'd feel safe would be to disconnect both shore power and battery while "soaking". .02$ FWIW
14apex is offline   Reply With Quote
Old 05-23-2020, 09:40 AM   #3
Since vinegar is conductive, I wouldn't be soaking it while your unit has shore power, or battery power connected. If you can isolate the 12 volt connection on the cord end (pin 4) where it connects to your unit you should be fine, but I wouldn't reconnect it until it was dry.
Camped: 2020 (Days/Nights) - 7/5
2019 (D/N):27/20, 2018(D/N):24/17, 2017 (D/N):30/25, 2016 (D/N):32/23
TT: 2013 26' Revere TBQB
TV: 2020 GMC 2500HD 4x4
glen1971 is offline   Reply With Quote
Old 05-23-2020, 09:50 AM   #4
1. Don't soak it with ANY power source connected. The 7-way plug will have +12 vdc on one pin any time a power source is connected (either the battery, or the converter if plugged into shore power). Vinegar is electrically conductive.
2. Be sure to rinse it with plain water after soaking to remove residual acidic vinegar.
NavyLCDR is offline   Reply With Quote
Old 05-23-2020, 01:55 PM   #5
You could use a can of electrical contact cleaner spray as used for electrical contacts in electronic equipment. Not that expensive and cleans contacts pretty well. Spray it on and work the connection plug. Be careful to test it first because sometimes it can be harmful to certain plastics. I use "Osborn" High Tech Electronic Cleaner #76334 from Osborn Manufacturing in Cleveland OH. Nice thing is it does leave a microscopic film for protection against corrosion, which could help prevent future problems. I've had the can a while, but, presume it is still made (or something like it). Hope that helps you.
ProfChuck is offline   Reply With Quote
Old 05-23-2020, 02:17 PM   #6
rsdata's Avatar
this is best not only to clean but to protect the metal connectors... I spray this on all connections/connectors on the trailer 12 volt or 120 volt...
Too much of anything is bad, but too much good whiskey is barely enough. Mark Twain
2014 Shamrock 183
Old 05-23-2020, 02:30 PM   #7
If I have a corrosion issue with electrical contacts I prefer to disconnect and manualy clean surfaces. Then reconnect and properly torque screws.
THEN I apply a contact cleaner/protectant.
"A wise man can change his mind. A fool never will."
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 05-23-2020, 02:38 PM   #8
Some folks...
Some folks let the umbilical fall into the mud when parked for a while. Contacts can tarnish, oxidize, rust, and even break off if it's been there a while. (Ask me about the break-off part.)
The proper stowage for the umbilical is tucked up into the propane tank shroud from the bottom.
Larry
Larry-NC is offline   Reply With Quote
Old 05-23-2020, 02:39 PM   #9
Yes, I agree with TitanMike, if you can manually clean the surfaces, that is the best way, then spray. rsdata's brand of contact cleaner is a good one also. I think I got my can of spray from an professional electronics dealer when I was designing our TV Studio about 10 years or so ago, but, that was a while back. It was a 16 oz can.
Old 05-23-2020, 03:47 PM   #10
My TT has a "cup" on the A-frame for the 7-way to nest in. Really convenient and actually useful. Thanks, Forest River.
Greg 'n Deb
2020 R-POD 195 HRE
Tacoma and Tundra TV's
Dirt Sifter is offline   Reply With Quote
Old 05-23-2020, 05:09 PM   #11
I use PB Blaster to clean electrical connections on my tow vehicle plug and the umbilical cord plug on my tt. I give them a shot every now and then as a preventative maintenance thing.
Bob
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
retiredcamper47 is offline   Reply With Quote
Old 05-23-2020, 05:13 PM   #12
Bob
Why would you spray something with oil in it on your electrical connectors?
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is offline   Reply With Quote
Old 05-23-2020, 05:14 PM   #13
And if you don't have one, they're cheap:
https://www.amazon.com/Boat-Camper-T.../dp/B006R5C0G4
2011 Traverse LT, 3.6L, FWD
Old 05-23-2020, 05:16 PM   #14
I use this one...holds it up in the air with the cap on top so water can't get in. Attaches to the jack. My jack cover provides additional protection
https://smile.amazon.com/HUSKY-TOWIN...0272134&sr=8-2
Old 05-23-2020, 09:11 PM   #15
Thanks all very helpful
Judd
Texas
2017 Forest River Salem Hemisphere Lite 32'
Travel Trailer Newbie
Old 05-23-2020, 10:00 PM   #16
KRedburn's Avatar
wd-40 to the rescue. It has many uses. Works very nice for moisture displacement on trailer connections.
Ken and Kathy Redburn
2018 DX3 37TS (The Taj)
KRedburn is offline   Reply With Quote
Old 05-23-2020, 10:53 PM   #17
jkoenig24
Another vote for Deoxit.
jkoenig24 is offline   Reply With Quote
Old 05-23-2020, 10:57 PM   #18
After it is clean smear some dielectric grease on the plugs. Lasts a long time to keep corrosion from forming and has a negligible impact on conductivity.
Hobienick
2020 Rockwood Roo 19
2012 F150 SuperCrew Ecoboost
hobienick is offline   Reply With Quote
Old 05-24-2020, 01:15 AM   #19
So, I shouldn't use the "holster" that came installed on my trailer tongue for that purpose? Who knew???
-Qwkynuf
2003 F150 Supercab 4x4, tow pkg, 3.55 gears
2020 Flagstaff Micro Lite 21DS
Qwkynuf is offline   Reply With Quote
Old 05-24-2020, 09:29 AM   #20
Since we've moved into coatings, remember where you live and play. There is a LOT of dust and dirt where I often go. Bare, dry connectors are best with blasts of compressed air to clean things out when needed. The stuff that protects in the humid, wet are not as helpful in the dry and dusty as they tend to gum things up. My $0.02.
Greg 'n Deb
2020 R-POD 195 HRE
