Old 09-15-2020, 03:56 PM   #1
Solar
Our 2018 3950tz is prewired for solar on the roof. Can I plug a 14w solar panel in there and assume it will keep my batteries topped off
loyda is offline   Reply With Quote
Old 09-15-2020, 04:30 PM   #2
A 14-watt solar panel is not going to charge those types of batteries, they're for charging your phone or tablet.
SacRV is offline   Reply With Quote
Old 09-15-2020, 04:30 PM   #3
Flybob's Avatar
No for several reasons.
Prewired for solar generally means simply a connector on the roof ( or side) and a wire to the area near the battery. You should get a charge controller to connect between the panels and the battery. Also if you are trying to overcome the parasitic draw and charge the battery, you will need more than 14W. I would add a 100W panel. ( 50W min).
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 09-15-2020, 04:50 PM   #4
Ok thanks
Old 09-20-2020, 07:09 AM   #5
Installed 14w panel on the roof to keep batteries topped off. Doing this temporarily while it's up for sale. Plug and play, very simple and working great. Now when I show to possible buyer everything works.Click image for larger version
solar
