PWM controller you could put 600w on it
BUT the output to the battery at max will be 400 or a bit more..
controller will only input/output 30amps (maximum specified for the controller)
battery charging voltage = 14.4v
Max can be sent to battery 14.4 x 30 =432w
600w of panels if you are in a BAD solar production area ..... may/would be of some benefit as long as you don't exceed the amps of the controller
if you in a good solar area ..... it is a waste of a panel
better off increasing the controller's amperage
good reading here from Renogy
https://www.renogy.com/learn-system-sizing/
