Originally Posted by Aussieguy
with 2 x 15000 BTU if you want to run them you will need generator
solar and softstart will belp you for about 10-15 minutes because you will need a HUGE battery bank and a FULL roof of solar 1000-1600w of panels
whether or not you need soft starts will depend on what generator size you get
I have a 30amp setup ...1 air conditioner I use a 3500w INVERTER generator if I want a/c
But usually just opt to pay for a campground with hookup rather than to deal with loading up generators/gas
Don't do a LOT of camping in the full summer months cause why pay for camping if all you do is run from trailer a/c...... to truck a/c..... to restaurant a/c
and the remaining months ... NO a/c required unless you go to southern Florida
Thanks for your quick response!
Sorry, I should have been more clear.
I do no want to use solar for the AC units.
I want the additional 200 watt solar suitcase just to help my existing 200 watt rooftop solar unit maintain the batteries (dealer provided two wet cells)so I can run small items with no generator.
I have purchased two generators (Predator 5000’s) and a “Y” adapter for when we run everything. A bit of an overkill but sometimes we will want no limits!
I want the soft starts just to help out the equipment wear and also ease on the generator (especially if only using one generator).
Solar - Leaning towards Renogy or GRECELL.
Still looking for proper Soft Starts.
