Old 05-24-2024, 09:36 AM   #1
solar controller and generator connection / operation
Can I run the generator and have the solar controller connected to the battery at the same time. My sense is the controller and the DC charging system would be in parallel and fight each other? Do I risk damaging one or the other?
It would be a pain to disconnect the controller every time I want to power an AC appliance ( coffee maker or vacuum during the daylight.
ErnieSeabee is offline   Reply With Quote
Old 05-24-2024, 09:44 AM   #2
Since I've no idea of your components or wiring, I'm reluctant to say no worries but generally, solar input can happen at the same time as others.
The solar controller will adjust it's output.
2024 Surveyor 252RBLE
2023 F150 Powerboost 7.2KW 4x4 1658PL with a WeighSafe WDH
DJ252 is offline   Reply With Quote
Old 05-24-2024, 10:33 AM   #3
There should not be any issues. The generator is the same as shore power for the batteries, so if it works on shore power it will work on generator. Using the generator as shore power would be preferable to using 12v out if the generator provides it (not as common).
2021 Ram 3500 HO DRW Megacab 4wd 3.73
2022 Riverstone 42FSKG | GenY Executive 6.5k
Airlift 7500XL Airbags w Wireless One Compressor
darrellr is offline   Reply With Quote
controller, generator, solar
