Solar Controller Heat/Location
Currently, I have 200W of Panels that are just placed on the ground for optimal Angle/location. The Panels feed an MPPT controller that is mounted in the trailer with the output of the controller connected to a fused location in the Converter Panel to charge the batteries. I've noticed that when the solar is putting out almost max. wattage, there is some significant voltage drop between the controller and the batteries (about 0.5v)..
Recently, I purchased another 100W of panels and need to upgrade the MPPT controller to support the additional wattage. I really want to mount the controller closer to the batteries and was wondering how much heat gets dissipated by the controller (the heat sinks are pretty large).. I want to mount it in the area of the V-Nose where the propane tanks are located so that I only have a short run of heavy gauge wire to the batteries.
Any thoughts would be appreciated.
Paul and Angela
Raleigh, NC
2018 Windjammer 3008w
